125-200cc My 2002 CR125 project
Discussion in '2 Stroke' started by Durangedgoat, Mar 19, 2016.
  1. Durangedgoat Husqvarna
    Indiana
    2002 CR125
    I'm going to give a little background here and share some pictures before I get started.
    The bike you see here is in it's assembled state. This is "not" how it was when I purchased it. Things began looking bright for this cycle. A local racer either had bought it new or close to it. Well let me share its current state.......
    The good:
    Most of the parts are there
    Front tire is like new
    shock and forks aren't toast
    Hinson billet clutch basket
    Pro Circuit Works pipe
    Renthal bars
    brakes are good
    Excel wheels (I'm guessing the factory wheels
    good aftermarket air filter
    That is about where that stops.... and now to the bad:
    No clutch
    Clutch hub fried
    cylinder questionable
    head needs checked for squish
    piston junk
    shift lever worn on wear end
    rear tire junk
    sprockets and chain worn out
    plastic beat
    Engine taken apart in many pieces
    seat has small hole
    front fender contacting clutch cable housing
    There is more but I'll stop there. Hoping to have it good to go for under 500 dollars. FB_IMG_1458429251776.jpg
  2. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    "Hope is the most quintessential human trait. At once your greatest strength and also your greatest weakness." The Architect of the Matrix
    Durangedgoat likes this.
  3. Durangedgoat Husqvarna
    Indiana
    2002 CR125
    This shows both the front and back of the cylinder wall and the pressure plate. Looks like It is going to need a bit of love. Does the cylinder appear able to repaired...That is my main question... I can feel a lip in the pressure plate, so I know its shot.
    I'm. Pondering going to a 144 cylinder. What would I need to get to use a 09-13 cylinder on the 2002 engine?
  4. Durangedgoat Husqvarna
    Indiana
    2002 CR125
    Ot
    I imagine a potential consensus would be to part this bike.... I wouldn't learn as much from the experience, however...
    My goal is to have this beast roosting by the middle of June...
  5. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    My comment related to the "under $500" part. Otherwise, hope you get it going and like it. If you want to go 144, why not just send your cylinder off for boring and plating?
  6. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    that will 165/167 wont it?
  7. Durangedgoat Husqvarna
    Indiana
    2002 CR125
    The ship has definitely sailed for hope of a 500 dollar budget getting it done. I know where I can get a 144 cylinder and head. The problem is they are for the 09-13.
    Is the power valve area the change there or should I just go 165? I'm thinking if I want to run with my friends KTM dual sport I ought to go 165. Besides that shouldn't this bike run with a 250 4 stroke and then some in 165 trim?
  8. gots_a_sol Husqvarna
    Charles Town, WV
    WR177
    17 250RR
    Power valves have to match the same year range cylinder (00-08 or 09-13)
    I had to replace a pressure plate a year ago and it was only about $20 new.
  9. Durangedgoat Husqvarna
    Indiana
    2002 CR125
    The clutch hub is bad as well. Quite grooved up. I could probably run with it, but like hell I'm gonna risk tearing up the Hinson clutch basket that came with the bike. The power valve part I understand. I'm wondering what other differences, if any, would prevent me from running the newer cylinder. I think I'll be better off going 165, but will I be able to retain the stock carburator.....
  10. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    stock will be fine but a Lectron:thumbsup: i know a guy with a stash of used ones if you wana try one for less$
    Huskynoobee and Durangedgoat like this.
  11. Durangedgoat Husqvarna
    Indiana
    2002 CR125
    Quote="troy deck, post: 571348, member: 10601"]stock will be fine but a Lectron:thumbsup: i know a guy with a stash of used ones if you wana try one for less$[/quote]
    Im hoping to re-use the stock carb, but also wasn't there a keihin that works better too? 36 or 38 mm ?
  12. Durangedgoat Husqvarna
    Indiana
    2002 CR125
    After seeing a FBF fork/triple clamp setup on Bill's MC plus ebay store I am contemplating building a hybrid. running newer race ready forks, updating the swing arm and rear brake brake etc. Going to look into plastic options as well. I love the colors and graphics of the these bikes. I just want it to rip at the same track as the outdoor national race is held here in Indiana.
  13. Jontteyy Husqvarna
    Husqvarna SM/CR125 -05
    Im interested in that Lectron, is it still available?
  14. R-J van Hulst Husqvarna
    Cambodia
    Honda CB 400 Vtec 3
    :D yes you will yet do you want?:D
    a lectron will transform the bike in a smooth operating and no finicky behavior mannered bike
    it also reduce your consumption of gas
    still want a stock carb :p
    Robert-Jan
    Durangedgoat and Ken Hynes like this.
  15. NicaJohn Husqvarna
    2004 cr125 02 cr135 02 wr144
    Kdx200,2015 beta 430rr
    What's he looking for on lectron? I have an 04 125 in middle of rebuild and my old mikuni was a pain in the balls. Finicky some days perfect off the next.
  16. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    all that go's away with a Lectron:thumbsup:
    SmokeyExpress and Durangedgoat like this.
  17. Durangedgoat Husqvarna
    Indiana
    2002 CR125
    I've also been looking at the tm designs chain guide. It would seem that even though I found some for a cr that are only supposed to work for 04- , they should work on my 02'. Or should I just run OEM? I'm probably going to run the oem slider cause their cheaper than a UFO which is also only listed for 04-. Is it common practice to swap to the newer swing arm? All the pivot parts seem to be the same.
  18. Durangedgoat Husqvarna
    Indiana
    2002 CR125
    I'm definitely interested in one of the lectrons.
  19. NicaJohn Husqvarna
    Same here if you're friend is parting with any.
  20. Durangedgoat Husqvarna
    Indiana
    2002 CR125
    I cannot post in real time so bear with me. I've come to the conclusion if aftermarket part cannot be had for the 02', its nothing some welding and creative machine work can't fix.
    NCSteve likes this.
