125-200cc My 2011 TE 250 vs a 14 cr 125.
Discussion in '2 Stroke' started by JasonfromMN, Oct 14, 2016.
  1. JasonfromMN Husqvarna
    MN
    None right now :(
    2013 Yamaha FZ6R
    I race enduros and some harescrambles. I have a 2011 TE 250 that's pretty worn out, but I know the bike like the back of my hand and the suspension is valved for me perfectly. I either need to do a rebuild with the motor and clutch this winter or, I have the opertunity to get a low hr cr 125 for a good price.
    Pros- I know my bike well and generally like 4 strokes.
    My bike is suspended and valved for my weight perfectly
    I really like the button
    The cr 125 should be much lighter than mine
    The cr should last quite awhile,it's almost new.
    Cons-
    I generall don't get along with carbs
    I "think" the cr suspension would be too stiff for tight woods
    I "think" the cr engine probably isn't easy to ride in the tight woods
    Thoughts?
  2. Zomby woof Husqvarna
    Ontario, Canada
    2011 CR 150
    The CR engine is exceptionally easy to ride in the woods, and with a few minor mods is even better. The carb is simple - there's a plug and play option that works, and the suspension is pretty soft. What do you weigh?
    I use my CR predominantly as a woods bike. I would highly recommend it.
  3. JasonfromMN Husqvarna
    MN
    None right now :(
    2013 Yamaha FZ6R
    I'm around 170. I haven't had a 2 stroke for 20 years. I know I'm just whining now but I like the e start. I don't think the CR has e start? Any idea on weight difference between them?
  4. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    No estart n id day around 10kg
  5. HuskyTaylor Husqvarna
    N.Harford co. Md
    09 TE310 12 WR 125
    01 FLHR 77 Triumph
    You don't need the button on the 125's. They start so easy I have started mine just by pushing it with my hand.
  6. Chef Husqvarna
    Ontario, Canada
    08 Cr165, 09 Wr165
    01 Husaberg FE650, 07 BMW 650 Dakar
    I think you will find that the cr is a huge improvement over your TE. The bikes are very light and flickable. I'm 175lbs. And switched from a husky cr250 3 years ago. I race xc and enduros on mine. Ive never looked back. No, there is no button. Yes, the ignition is much hotter than the wr and the hit comes on fast. The suspension on my 08 works fine in the bush but better when you are pushing it. Mine have grown from a 125 to a 144 and now a 165. I had some issues getting the bike working well for me early this season but seem to have sorted it out and now I'm faster than I've ever been. I have a lectron carb which is very easy to set up the bike gets great fuel mileage. Maintenance is a breeze on the little bikes. I can do a top end in under an hour.
    Bill502 and wallybean like this.
