My IMS Tank is Alive!
Discussion in 'General (Main)' started by cobb92, Apr 6, 2011.
  1. fletchman45 Husqvarna
    park rapids
    This is so bothering me!! I refuse to not have a check valve. What the hec is the deal????
  2. moto66 Husqvarna
    England
    I could only think of a hose with a slosh baffle in it as an alternative? It would allow 2 way air flow but stop fuel freely running out. Maybe..
    fletchman45 likes this.
  3. fletchman45 Husqvarna
    park rapids
    This sounds like a good idea and that I would probably do.
  4. moto66 Husqvarna
    England
    I've read too many bad posts on aftermarket tanks so I've decided not to buy one. I've never had a problem with my 09 510SM's tank so for longer trips I'm carrying the spare. x2 fuel cans one litre each in a Kriega tailpack. Cans £10.00 each. Pack £25.00. For shorter trips dump it and run with the standard tank. Saved a bunch of £'s and a bigger bunch of bother.
  5. Huskman Husqvarna
    Fort Bragg CA
    2012 TE310
    I am having the exact same issue. leaking around the fuel pump gasket.
    I have tried everything from honda bond the Black RTV... nothing is working!! I am also Sad :cry:
    did you ever fix your issue with it leaking around the fuel pump Gasket?
    -Huskman
    duggoey likes this.
  6. XLEnduroMan Heroes Ride Huskys. The others follow.
    Durham, CA.
    '18 Husqvarna 701 Enduro.
    '20 Ducati Hypermotard 950.
    I have had good luck in the past on some float bowl gaskets (a British and a Japanese bike) by taking the time to evenly wrap the float bowl gaskets(s) with Teflon tape. Get some 1/2" or 3/4" tape and angle it at the start and "fatten" the gasket up as you see fit. Button it up see how it goes. My fixes held up without another issue.
    I free vent my fuel tanks on my Husky's. I have seen the check valves pressurize the tank, so I don't use them. Pressurizing can clearly warp a fuel tank.
  7. duggoey Husqvarna
    NSW, Australia
    2010 TE 310
    KTM 690, Yamaha WR200, FGS650(800cc)
    Have you tried this stuff?
  8. Huskman Husqvarna
    Fort Bragg CA
    2012 TE310
    Yes that was the first stuff I used. it work for maybe 2 months then the fuel ate the sealant and started to leak again.
    -Huskman
  9. Huskman Husqvarna
    Fort Bragg CA
    2012 TE310
    I have been looking at different kind of Sealants one is called loctite 5910 and Permatex, Hylomar Racing Blue and wellseal. which one would work for my leaky fuel pump gasket issue?
    Thanks
    -Huskman
  10. Coffee CH Owner
    Keep in mind this is a really old thread, some of the people that previously posted may no longer log into this site - just do not want you to be disappointed.
  11. Buster714 Husqvarna
    SoCal
    2011 TE310
    '04 950Adv, '10 F800GS, '06 R6 track
    IMS says Hylomar M (previously Hylomar Racing Formula) is an outstanding gasoline-resistant sealant.
    I have a 2011 TE310 and my IMS 2.9gal has sprunk a leak around the gasket on the bottom of the tank as well. Fortunately, IMS is sending me a new tank, but I'm not looking forward to getting everything out of the leaky tank and into the new one! :(
    [IMG][IMG]
    I bought a new aftermarket fuel pump from someone who purchased one and then sold their TE. Do you guys think I should replace the stock fuel pump while I'm in there? (If there's a better place to ask let me know Coffee.) I had the bike stall on me in 100*+ weather but I think it was vapor lock because it went right back to normal later that day. I'm planning to seal the bottom gasket with Hylomar and hopefully avoid this whole fiasco moving forward.
  12. Motosportz CH Sponsor
  13. Buster714 Husqvarna
    SoCal
    2011 TE310
    Hmm, that might be a good way to keep that gasket seated on the tank while it expands/contracts.
