250-500cc my mate has a hankering for a hydraulic clutch on his 300, I reckon...
Discussion in '2 Stroke' started by marshwater, Aug 17, 2015.
  1. marshwater Husqvarna
    WNC
    '12 TE449 (sold) '13 WB165
    2011 wr300. Any insight or experience is appreciated.
    Cheers!!
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    a motion pro cable properly routed and lubed is nice
    there are hydraulic kits, but they are that, kits
    you are essentially taking motion and making it fluid then returning it to motion
    the true hydraulic clutches are slightly better but for the money you could buy a new cable every year
    ray_ray and ohmygewd like this.
  3. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Properly adjusting the pushrod at the clutch basket so that the arm/lever at the engine has the correct geometry (disengages across 90 degrees to cable) makes more difference than a cable upgrade but the Motion Pro cable does help.
    ohmygewd likes this.
  4. CCP Husqvarna
    NJ
    04 WR250 11 WR250
    I had the hebo/AJP on my 250. Took it off and went with the MP cable. If you want to play with it you can have it cheap. 2 masters 1 slave, extra o-rings. To be honest, I think the cable is an easier pull.
  5. husky jim Husqvarna
    USA
    14 WR300, 87 430wr, 86 430ae, Tr650
    Rekluse exp 3.0 and you will never need touch the clutch lever again!
    My 2004 ktm 250 with a hydro clutch had just a slightly harder clutch pull with less feel than my 2014 husky wr300 did new.
    I went to the Rekluse a few months after I bought it and haven't looked back!
  6. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    my magura hymec set up is pretty sweet.
    ray_ray likes this.
  7. pjay303 Husqvarna
    2012 WR 300
    I recently purchased the pro taper profile clutch perch assembly and it made a huge difference. That and a lubed up motion pro cable like stated above is almost as good if not better than the hydraulic clutch on my 14 fc450
    ray_ray likes this.
  8. ray_ray Mini-Sponsor
    The Philippines
    If he's just looking for an easier pull on the lever, maybe he should learn to use 1 or 2 or 3 fingers on the clutch when riding so that the work is distributed across different muscles ... I use any combination of 3 fingers at any time when riding, depending on whatever ... The clutch lever is what I play with all day long when riding ... It's like playing sweet music on a guitar .. Coming out of a corner and feathering correctly to a high degree, is what I'm looking for in both engine sound and the hook-up feel ... I might have watched too much dirtbike racing? (RV2 did a pass on Nagl earlier this yr in EU and the clutch-hogging sound captured on VID was just too cool)
    The juice clutches are much easier to feather when riding it seems ...Mine feel exactly the same on 999 out of a 1000 pulls .... Always easy to find the sweet spot to keep the rearwheel hooked and the RPMs going ... The manual clutch on my WR250 is a little harder to feather correctly ... As many have stated above, cable routing and keeping it lubed helps greatly there, but the feathering still takes more precise finger work ...And that's OK as seat-time is all that is needed there.
    If he's got the duckies, stick the juice clutch on there but keep the cable so he can revert back if needed ...
  9. Farmer John Husqvarna
    Santa Clara, CA
    2009 WR300
    92 WR250, 01 KTM 400MXC
    Same here!!
