125-200cc My New 2013 WR144 with Lectron
Discussion in '2 Stroke' started by Yellowfin, Jan 3, 2015.
  1. Yellowfin Husqvarna
    Ocean City, NJ
    '13 WR144
    kdx220 (sold)
    I am super stoked! Just picked up a leftover '13 wr144 with a dealer installed lectron.
    What are the important hop ups?
    Tips on tuning lectron? (Running really rich)
    How should I break the motor in?
    Thanks this forum was pivotal in my decision, almost went with a 310 but came back to the 144 with the recommendations of this board
  2. R-J van Hulst Husqvarna
    Cambodia
    Honda CB 400 Vtec 3
    Get the suspension set up for your riding and person
    pretty much done deal after that.
    if you are interesting in pimping up the bling factor then there is a whole list to follow.
    Robert-Jan
  3. Yellowfin Husqvarna
    Ocean City, NJ
    '13 WR144
    kdx220 (sold)
    Is there a way to turn the lights off or are they always on?
  4. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    are you familiar with the lectron? where do you feel its running rich? is the float level riding inside the markings on your bowl?
  5. Yellowfin Husqvarna
    Ocean City, NJ
    '13 WR144
    kdx220 (sold)
    I am not familiar with it. But Its smoking alot! it could be because its new??
    I have no idea which is idle, metering etc.. I have no instruction and the dealer wasn't very helpful
  6. firebolter Husqvarna
    Annapolis
    06SM610
    13TE300Berg,07KTM525EXC,13 HusWR165
    Go to the lectron website and download the tuning guide. Has all you need to know to set it up to the best tune.
  7. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Love the fact the reed block is on the cases and not the cylinder!
    Keeping my eye out for 125/44 in uk
  8. justintendo klotz super techniplate junkie
    yes very easy to tune. its smoking, but does it run well? i would not base my carb tuning on how it smokes. check out the lectron site and it you have questions we can help. you should be somewhere around 40:1, maybe 32:1 if raced. when jetted correctly i have had no smoke or spooge problems with 40:1.
    Cosmokenney likes this.
  9. Yellowfin Husqvarna
    Ocean City, NJ
    '13 WR144
    kdx220 (sold)
    Thanks, I will try to figure it out tomorrow.
    It runs fine but I have excessive smoke and Spooge at high rpm?
    When the idle screw is 1 1/2 per motosportz thread it idles super high.
    I'm sure I just new to get it adjusted properly.
  10. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Basically you adjust the Lectron from idle all the way through 7/8 throttle by lengthening=leaner or shortening=richer the needle. Once you have that done you adjust the wide open/last 1/8 by turning the power-jet clockwise=leaner or counterclockwise=richer. Set the idle where you want it and you're done... altitude has very little effect on it. If I'm going to ride in the sand all day especially on a cold day with good air I will turn the power-jet screw out 1/4 turn to make it a tad rich so it's easier on the engine when you're pinning it all day.
    The lectron webside will explain how to turn the needle and then re-index it so the the flat side is facing the engine.
    Xcuvator and Motosportz like this.
  11. Caferacerman Husqvarna
    Did it smoke and Spooge before the Lectron?
  12. Yellowfin Husqvarna
    Ocean City, NJ
    '13 WR144
    kdx220 (sold)
    I don't know, lectron was installed by dealer when I bought it.
    I can see the carb doing it unless it's injecting way to much feul at high rpm wich is the only time its spits the grey
    Could it be un burned fuel??
  13. Motosportz CH Sponsor
    Pretty much spot on. All I can add is don't forget to play with the external powerjet as it has more overlap than you might think on some bikes.
  14. justintendo klotz super techniplate junkie
    the hole for the powerjet is halfway up the carb body, so i thought the powerjet is operational over 50 percent throttle.
  15. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Thats the choke hole the powerjet hangs down into the top 3rd of the opening.
    Or am i again confuddled.
  16. justintendo klotz super techniplate junkie
    it depends on which nozzle is installed. mine hangs down right at halfway. i have seen some that the nozzle only hangs down a third. im guessing this is how you tune when you want to powerjet to work. my manual states the purpose of the powerjet is to"fine tune mid to high throttle positions"
    edit: i see lectron offers two different nozzle lengths. one must be half like mine and the other upper third like you have. i need to try the shorter one
  17. Yellowfin Husqvarna
    Ocean City, NJ
    '13 WR144
    kdx220 (sold)
    I got it all figured out. Kevin at Lectron was super helpful! Bike is running crisp!
    Motosportz likes this.
  18. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    That explains it, what benefit would shorter powerjet be? Opens up at higher throttle opening
  19. Yellowfin Husqvarna
    Ocean City, NJ
    '13 WR144
    kdx220 (sold)
    Do you guys have a recomendation for what plug and gap to use for the 144 with lectron? Even after leaning out the PJ I still seem to have to much unburned fuel
    Thanks
  20. justintendo klotz super techniplate junkie
    i guess it wouuld depend if you want the powerjet to work in the top half of throttle, or just the top third.
