I have a Strada in Terra form which is what i wanted as the wheel sizes are nicer for on road riding. Here are the before and after pics and a small home made item in the second pic pic
Thanks for that, I had in my mind to get the Strada to look like the Terra as its much nicer IMO but found that the front 19" wheel does track well and is a complement to the front suspension. Its a great all rounder and still I like my GS1100 as they are totally different bikes, which is nice.
Bikehunter, do think the stock low fender can be modified to fit the terra? 21 wheel Nice job looks good.
Thanks, the front fender is close on the 19" wheel and its not as good as keeping muck off the Radiator, I think its best to check out the rolling circumference of the two wheels to see if they are nearly equal.
Plus you would require the rear bracket to mount it, I have used mine to mount the tax disc but its hard to see in these pictures
I believe he said it was a custom home built cap. I used a metal 3/4" automotive plug from Ace Hardware. Bent the pins out a little and fits great. Like this, but smaller: http://www.fastenal.com/web/product...rd=&rfqId=&rfqLineId=&zipcode=&filterByStore=
Nice Job. I like it! As I can see from the pictures you have an ABS version and risers mounted to get the steering bar higher. Which length did you use or how high could you go without having too much tension on the cables and especially the brake tube when moving the bar to max left or right?
Ah no they are the standard risers, its interesting as I have a set of Renthal bars and they would be great on the bike but are an 1" longer each end and I was wondering the same about the cable length etc so do not know that answer?
