125-200cc Need a couple torque specs, 09 CR125
Discussion in '2 Stroke' started by montgob1, Apr 28, 2011.
  1. montgob1 Husqvarna
    The 6mm axle pinch bolts on the fork legs. The Maizochi manual doesnt translate to well for me.
    Are these the "wheel axle Allen Screws"? Because the ones on my bike are not allen heads, and
    4.4 ft/# seems pretty light. Also, i am looking for the cylinder base nut and cylinder head bolt torques if anyone has those handy.
    Gruppo registro compressione su tappo - Compression adjustment set on cap 20 ± 1
    Tappo su portastelo - Cap on slider 20 ± 1
    Vite spurgo olio - Oil draining screw 0,5 ± 0,1
    Dado di fondo su gruppo cartuccia - Foot nut on cartridge unit 50 ± 1
    Controdado su gruppo estensione - Controdado su gruppo estensione 20 ± 1
    Dado gruppo estensione - Rebound unit nut 6 ± 1
    Vite gruppo compressione - Compression unit screw 10 ± 1
    Viti a brugola bloccaggio perni ruota - Wheel axle Allen screws 6 ± 1
  2. wallybean Mini-Sponsor
    Montana
    Use 15 ft.lbs. for head and cylinder bolts. I don't have a torque for the pinch bolts.
  3. jmetteer Husqvarna
    Woodland, WA
    TXC300 CR125 CR144
    WR250F, TRANSALP
    7.7 ft lbs for the front axle pinch bolts.
    That is from my TXC manual, same forks and axle as the CR125...
    Later,
  4. PC. Husqvarna
    Beaverton, OR
    CR165 & CR144
    KTM500
    Every time I strike gold and decipher one of those riddles I'll throw a fist pump! :banana:
    What really helps me is to have a manual around for a similar style bike (yz250 in my case) and use it for reference. Most of the torque values are similar and I can usually figure out that a 'Left lower retainer fork rod holder' is actually just a lower triple clamp bolt.
  5. montgob1 Husqvarna
    Its kinda funny,my CR manual has i think about 7 torque specs in it. It has the upper triple tree clamp bolt.. but not the lower? Its a good thing encyclopedia Jake is around to keep me from screwing things up!
  6. LawnDartMike Husqvarna
    Salem, OR USA
    When in doubt I use this from the manual:
    Bolt Size................ Nm.............. Kgm............ Lb/ft
    M5x0.8 ............... 4.9-6.9 ......... 0.5-0.7 ....... 3.6-5
    M6x1 .................. 8.8-9............. 8.0-9.1 ....... 6.5-7.2
    M8x1.25 ............. 21.6-23......... 2.2-2.4 ...... 16-17.3
  7. pahusky Husqvarna
    Hummelstown, Pa
    '14 TC250
    '12 250XC '09 1200GSA KLR650
    I'm going to try and attach a pdf of part of a '08 WR125 shop manual. These are the English pages of torque specs.
    If the attachment does not work and you want me to email it, send me a pm with your email.
    Hopefully it works...
    Hey it looks like it worked! Can anybody else open it?
  8. LawnDartMike Husqvarna
    Salem, OR USA
