250-500cc Need a flywheel puller
Discussion in '2 Stroke' started by Brian Scott, Oct 25, 2013.
  1. Brian Scott Husqvarna
    Bainbridge Island, Washington State
    '11 WR 300
    '01 CR 500R
    What size is needed for a '11 wr 300? 22 mm x 1.5 RH threads? Thanks!
  2. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    is that a question or an answer? that sounds right its the same puller for my wr 250 and 360 so i can only imagine its the same for your wr.
    yes that sounds reight 22x1.5 rhd
  3. ks9mm Husqvarna
    NJ
    2015 TE 125
    2014 Beta 300RR
    Can flywheel puller be home made? Or it's best to buy one that works? How much do thy cost?
  4. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Like 15 bucks or 9 pounds
    Not worth the time attempting to make your own unless your board and have a lathe.
  5. Brian Scott Husqvarna
    '11 WR 300
    '01 CR 500R
    So I finally ordered the Motion Pro puller (part # 08-0074, http://www.motionpro.com/motorcycle/partno/08-0074/), which is a solid (not hollow) bolt, which will arrive tomorrow. WR models are not listed w/the bikes that this tool is compatible with (various Honda XL/XRs and various Kawi KLRs). However, Dennis Stubblefield Sales lists the same type of puller (part # MP#11, http://www.dssalesusa.net/catalog.pdf), only it being a hollow bolt, for 1990 to present Husky WX and WRs along with the same XL/XRs and KLRs as the Motion Pro tool.
    So, do I need the hollow bolt, or will the solid bolt work? Seems like the solid bolt should work.
    Thanks
  6. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    So you hold the flywheel with a clutch holder type tool and wind the solid bolt in?
    Or the outter is wound onto flywheel then the solids wound into the outter holding with spanners? Either will work you just have to hold the flywheel if its a single bolt job.
    Sorry my phones being strange an wont load up hyperlinks.
  7. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    P.s. Half the reason for a separate outer is to give the bolt enough threads to push on, you dont want to be winding a puller onto two threads it will just tear them off.
  8. woodzi Husqvarna
    Waterloo, ON
    You need to drill the solid Motion Pro puller to make it work. Easily done, they are not hardened. I did mine with a hand drill and a 5/8" (I think) drill bit. Drill deep enough so it engages at least 5 or so threads. Tighten with a wrench as best you can, give it a whack with a hammer, tighten again, whack, repeat as required until the flywheel comes off.
  9. Brian Scott Husqvarna
    '11 WR 300
    '01 CR 500R
    Thanks woodzi! Yes, I definitely need the hollow bolt, or drill out the solid bolt as you suggest.
  10. ERIC EDER Husqvarna
    2014 WR 250
    SUPERDUKE, GS 750 CAFE, DRZ 400
  11. rancher1 Husqvarna
    WA
    That is a nice kit but I do have more than 10 flywheel pullers and I just buy them when I need them.
  12. ERIC EDER Husqvarna
    2014 WR 250
    That's the only kit that has the one flywheel puller that we need for the huskies
