125-200cc need help...had clutch apart '08 cr125
Discussion in '2 Stroke' started by scrambler, Mar 28, 2010.
  1. scrambler Husqvarna
    ontario
    First off I think I may need to post some pictures for better illustration...I can't get no resistance to the clutch lever.Clutch cover is off,I believe the problem is where the ball bearing fits into a sleeved cylinder then the push rod fits into that.From the Manual it appears that there is another bearing and push rod?
    At any rate as you can tell I'm bit of a rookie here,please fill me in.
  2. dirt-dude Husqvarna
    Pa.
    There are 2 push rods and 2 balls, a flat roller bearing and a washer
    the roller rides on. Usually the ball that fits in the top hat against
    the end of the rod gets dropped on the floor and the other ball usually
    doesn't come out of the shaft unless you remove it.
