Need help on E41 code
Discussion in 'EFI/carb' started by HeyPlumberMan, Jul 5, 2015.
  1. HeyPlumberMan Husqvarna
    Missoula MT
    2013 TE 511
    I have a 2014 TE511 and the bike keeps giving me this code and wont run. It ran good untill i ran out of gas about a mile from my campsite. filled it up and started to ride for about a mile and it shut off. i have tried to reset it from reading other posts but noting seems to work. any ideas?
  2. Jose Carrillo Husqvarna
    2014 te511
    i had a similar problem look at the electrical connector that comes of the valve cover into the spark plug should have three wires coming off of it those wires arced on my bike because oil overflowed into the airbox and seeped out onto that connector i re wired it and filled the conector with rtv on the side with the wires coming out so oil wouldnt get in anymore ive put 9600 miles on it and its holding. not sure if this is you problem but its worth a look ill post a pic when i get home
    HeyPlumberMan likes this.
  3. Dangermouse449 Husqvarna
    Sunshine Coast QLD Australia
    2011 TE449
    2009 CRF450R 2000 YZ125
    That E code is just the calibration number for the dash.
    Engine codes can only be seen with the dealer diagnosis software HST.
    Check the regular things like spark at the spark plug, can you hear the fuel pump run (give the start button a quick touch, then release, you should hear the pump whirring).
    Check the fuses. Try swapping the relays to different positions (They are all the same p/no.)
    If these are ok, it's possible the filter 'sock' on the fuel pump is blocked, or an electrical fault.
    HeyPlumberMan and Jose Carrillo like this.
  4. HeyPlumberMan Husqvarna
    Missoula MT
    2013 TE 511
    Thank you guys i will try those ideas and let you know how it turned out.
