Need help! Slipper clutch install
Discussion in '4 Stroke' started by So Cal SM450R rider, Feb 28, 2009.
  1. So Cal SM450R rider Husqvarna
    So Cal
    Ok, so I finally get my slipper clutch that has been on back order since Dec. Its an Adige/Adler HU-52 for my 08 SMR 450. I follow the directions and even look at the install video from the website. I take out the old clutch pack and put in the new one. Everything is good until I put the original pusher back in followed by the pressure plate. The new pressure plate has a bearing in it which will not fit over the front of the pusher shaft. I think I might have the wrong pressure plate, (God I hope not) but I'm not sure. Not only that but there is a large black concave & grooved washer that came with everything and there is no mention of it in the directions. I don't know where it is suppose to go. Here are some pics of the pressure plate, 9 washers for the variable spring tention, the stock pusher, (which has its own bearing between 2 flat washers) and the black washer. Someone please help me!!!
  2. Coffee CH Owner
    Moving from Tech ref to the 4st section.
    Tech ref is for keeping track of the handy "how to" info like checking valves & rejeting carbs. 4st is where questions are asked.
