Need new Battery '05 TC450
Discussion in '4 Stroke' started by HuskyT, Dec 15, 2008.
  1. HuskyT Moderator
    Corona, California
    Can any of you guys reccomend a new battery for my '05 TC450 at a great cost...
    My three year old battery is toast now ( has never let me down ) and with the cold weather actually moved into SoCal ... lot of rain , snow at higher elevations the old oil is a little bit thicker than normal... I wheeled my bike out of the garage to give her a quick run but my battery gave up the ghost and I have no kicker on this bike!
    Tried a trickle charger for about 6 hours on it with no luck......
    Looking for something economical as Christmas is here and funds are low....!
    If any of you can recommend a battery and where to get it much thanks in advance!
    T
  2. pvduke Husqvarna
    ... on the gas...
    tripple-hondo hoosk...
    Pep Boy's
    Kragen.
    Chaparral and Cyclegear.com. (Chapy is having a blowout right now).
    p/s- if yas rided it more ya woodent have this problemo..:p ;)
  3. Joliet Husqvarna
    Vista, CA
    I don't know what battery yours uses but the new TE's use a Yuasa YTZ7S. I ordered a replacement from BatteriesPlus in Phoenix 602-841-3900 the battery number is CYLAZ7SXTA. It was $70 plus shipping It is the same size as the Yuasa YTZ7S and has the same 130 CCA and 6Amp/hr, Its also an AGM and has a 1 year warranty.:) Ken
  4. HuskyT Moderator
    Corona, California
    Ain't that the truth.... :D
  5. HuskyT Moderator
    Corona, California
    Thanks!:thumbsup: Cycle Gear wants approx $100 so this is good info!
  6. pvduke Husqvarna
    ... on the gas...
    Did ya check Pep Boys and Kragen yet?
    P/s- disconnect yer Negative cable if she's gonna sit for a while.
  7. Coffee CH Owner
    Another option is the yellow pages under 'batteries' - and of course TT store... if the order is big enough free shipping.
  8. HuskyT Moderator
    Corona, California
    pep boys - do not carry 7 series
    Kragen - do not carry 7 series
    Cycle Gear Yuasa $100 +
    Corona Motor Sports Yuasa $114 + tax
    or Corona Motor sports : Power Source Brand Battery PN# WPZ-7S$59.90 ( made in Anahiem, California) 180 CCA 6 month warranty
    I called Power Source and asked them about the difference. They stated that the Yuasa is overpriced and that Yuasa has steadily been raising their prices this year. HE said "Yuasa makes great batteries but so do we" .... i like his honesty.....
    Any of you familiar with/used a "Powersource battery"? Honestly at half the price of the Yuasa and slightly better than "Batteries Plus" and more CCA than either of them , I'm willing to try it.
    What do you guys think? http://www.powersourcebatteries.com/bat.htm
    T
  9. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
  10. flyingbob Administrator
    USA
    01&02WR360_02WR250_02CR250_12WB165
    01 VOR400_07 TM450_22 GG250_07 Tuono
    I've used a **5lbs agm battery in my te450 & tc250 for a while now & have never had a problem. A lot cheaper. Lower CCA but I've punished the heck out of them cutting trails. Big deal to fully charge them before ever using them. They'll tell you they're at 80% after putting the acid in, but still put them on the charger for 10 hours or more. AGMs need to stay fully charged to live & prosper.
  11. HuskyT Moderator
    Corona, California
    I'm going to ask a stupid question but isn't an AGM a no liquid/acid type sealed battery?
    Also what is ** 5lbs ?
    Also, if charging do I charge at 12v 10amp or 12v 2amp on my trusty Sears Craftsman battery charger on one of these batteries . Do I need to do it before install?
    Thanks, T
  12. Joliet Husqvarna
    Vista, CA
    Most of my small batteries recommend 1.5 amp charging. Do yourself a favor and get a small battery tender. They usually run about 30 bucks and they have probably saved me hundreds of dollars worth of batteries.
    Most of the AGM's that I have seen have a gel type electrolyte in them and they are sealed. If you are putting in acid then it is not an AGM.
    :)Ken
  13. pvduke Husqvarna
    ... on the gas...
    Getta kicker lazy-bones!
  14. HuskyT Moderator
    Corona, California
    When your swearing and spitting and cursing when your stalled bike won't start during the next race......i'll just smile and remember that little comment:D:D:D if it happens to me .....I'll just hit that magic red button and save my sweat for the next bone jarring set of whoops ! or when your boots have 20lbs of mud on them and you have to kick it over ... I've seen guys quit races over kicking their bike......
  15. HuskyT Moderator
    Corona, California
    Ken, do I need to precharge or can i just throw it on the bike? I'm assuming for now if I need to pre-charge I can charge at the 12v 2amp and be fine on my existing Crafstman charger?
    T
  16. Joliet Husqvarna
    Vista, CA
    The one I just purchased, I put on a Battery Tender Junior and it said it was fully charged within about 10 minutes. That would have been plenty of juice to start my bike just fine and just let the bike charge it.
    I don't think it is necessary to charge it, but do not use the 10 amp setting if you are going to do it. The 2 amp setting should be fine, but refrain from over charging it. :) Ken
  17. pvduke Husqvarna
    ... on the gas...
    Pfffft...my TC starts so eays you could use a slipper. Hot or cold.
    Use a trickel charger, millilamps, not full amps, slow and steady....Battery Tender does it best...disconnect the Negative cable when not in use or charging.
    E-starts are for girls. :doh: :lol:
  18. flyingbob Administrator
    USA
    That's where you go wrong and the battery goes to the dump. It does need charged. 1.5 for 10 hours when put into service. The AGMs are two types. Factory activated and sealed; & aftermarket where you have the neat 6 pack puncture packs and then you put the non-removable sealing strip over the holes.
    The ** is the prefix JT YT XT, depends on whose catalog.
  19. Joliet Husqvarna
    Vista, CA
  20. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
