justpinit
I have 2012 wr 300. When it gets to a certain temperature it shuts of as if i hit the kill switch. After about a min it starts again. It usually happens after wide open throttle, then when i slow down it dies. I suspect the ignition coil\cdi since it gets a fair amount of heat from being close to the cylinder head, and of course the higher demand of higher rpm's. I heated it up w a heat gun and a meter attached, and noticed a what i think is a significant change in resistance. I measure w the four pronged plug off from red to black input, and then from red to spark lead,and black to spark lead. I need cold readings and warm readings. Will post a video later of it happening if needed.
