Neutral light
Discussion in '4 Stroke' started by glane5910, Dec 26, 2015.
  1. glane5910 Husqvarna
    Bakersfield, CA
    2014 TE511
    2015 Triumph Tiger 800 XCX
    My 2014 TE511's neutral light doesn't work. Is this a common problem?
    Thanks
  2. Andy519 Husqvarna
    2012 TE449
    KTM 530exc, Ducati HM 939SP
    Did you sort this out? The neutral light on my 2012 TE2012 just stopped lighting up. I know the light works because the dash flashes all the lights on startup - including the green neutral light. I reckon it’s a problem with the switch or a loose connection after messing around behind the headlight replacing indicators. Doesn’t seem to affect the bikes operation that I can notice.
  3. Bioman2016 Husqvarna
    Riverside, CA
    2013 TE449
    2005 Kawasaki KFX50
    Are you sure you have a neutral light? I have a 2013 TE449 and I only have 3 lights. Blue is for high beam, green is for blinker, and orange is for low fuel. No neutral on mine or my buddy’s TE 511.
  4. Andy519 Husqvarna
    2012 TE449
    Ha! You’re right on the money. I just went out for a look - indicator (GREEN), hi beam (blue), low fuel (orange). Another mystery solved, cheers mate.
    Bioman2016 likes this.
