new 250f / 125 frame possible issue?
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by NWRider, Jul 27, 2010.
  1. NWRider Husqvarna
    When I pulled the subframe off my bike last night I noticed that the lower subframe mount points on the frame hold a lot of water in them. Could this cause rust over time? I was thinking maybe I should drill some small holes just above the weld but I do not know if that would weaken the mounts. Should I worry about this?
  2. Motosportz CH Sponsor
    Not noticed it being a problem on my two bikes with that frame. :excuseme:
  3. KEVTE510 Husqvarna
    Australia
    Husqvarna TE510
    I have a new 2010 model TE510 with just 300kms on the clock. I removed my plastic skid plate to find a pool of rusty water sitting inside the skid plate. I tracked this down to a drip of water coming from small holes at the bottom of the frame. I sprayed WD40 into the frame to help flush the water out. Love the bike but I am also a concerned about water sitting inside the frame that is obviously causing rust.
