new bike
Discussion in '610/630' started by tlking6, Jan 9, 2009.
  1. tlking6 Husqvarna
    Vista, Ca
    Finally got the O2 sensor bypass part of the power up kit today (I already changed the pipe) and after dealing with the broken plastic fuel pump fitting fiasco, yep, I tried to unplug my sensor by just lifting the tank a little to get to it without disconnecting the fuel lines. (big mistake as the red one just snapped) I took it for a ride.
    All I can say is :applause::applause::applause::applause::applause:
    Its a whole different bike now.
    For anyone wanting to know how to fix the plastic fitting nightmare, you can check out this post on Advrider.http://www.advrider.com/forums/showpost.php?p=8664047&postcount=8777
    I recommend drilling out the port to 9\16th before tapping otherwise its pretty easy,,,as long as your handy with a tap in close tolerances.
  2. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    Glad you got everything sorted out on it and got to ride the beastie.:thumbsup:
  3. tlking6 Husqvarna
    Vista, Ca
    Thanks Mimi, wish you were going up with us today. I've got my camara all set to record the carnage!
