New Husky owner, little concerned?
Discussion in '610/630' started by Bill B, Mar 14, 2013.
  1. Bill B Husqvarna
    salmon arm, B.C. Canada
    2011 630 TE
    Just bought a 2011 630 TE with 600 miles on it with mods done, Power Up, FMF pipe and JD tuner. When he fired it up in his garage it started a little slow but started. When i got it home a tried to fire it up and it was next to impossible, sputtering and almost firing and finally cranking throttle all the way it started. Ripped around the subdivision and it ran great. Warmed up and it fired up great. So question is i ordered the temp sensor, is it located behind the cylinder head with two wire plug connector? I also had fresh 94 octane gas in it.
    I have never owned a husky and I have my 08 wr250 x yamaha forsale but I'm wondering if i am selling the right bike? I need some good old husky confidence boys!
    Thanks for any help!
    Bill in Canada
  2. RDTCU Husqvarna
    '11 630SMS
    It'll be fine. If you short crank it once or twice when starting up cold, it will take a bit of coaxing like you describe to get it cleared out and fired up. If it's cold-cold, you might try using the cold start lever over the brake lever.
    If the temp sensor were bad, the fan would most likely be acting up and you would have trouble hot starting.
    I know it's generally warmer down here, but mine will crank right up on a normal day, but if it's cold, I may roll in ~10-15% throttle as soon as I hit the button. Very rarely does it take more than 3 cycles to fire, but if I short-crank and let off the starter too early, it will take a bit more cranking.
  3. DYNOBOB Husqvarna
    Welcome Bill. If I let mine sit too long without charger or the idle is set too low it will act like that.
    Will be in your part of the world end of July. Kamloops, Nakusp, Kaslo...
  4. kirbybikes Husqvarna
    Hi Bill,
    Welcome to the club. The Husky will be fine, like RDTCU says use the cold start lever and maybe a little throttle. The bike is great and I have a lot of fun on mine. Once you get past the Husky/BMW/KTM/Cdn distributor fiascos you will really enjoy the bike. Where did you pick it up? West Van? International? Or Burnaby? Lots of good info and very helpful people here. Most of the minor problems and mods have been figured out. Sounds like your bike is pretty well sorted, hit up JTemple for the service manuals and all will be good.
    Kirk
    Vancouver
    PS Check out adv rider and BC Big Adventure Trail Ride, for a Sept ride in your area. http://advrider.com/forums/showthread.php?t=747592 No info on the new route but a fixed date at the end of the thread.
  5. Bill B Husqvarna
    2011 630 TE
    Thanks Guys for the replies, I read all the posts for hard starting and it seems it would be temp sensor the fan runs when cold but no flashing netural light. is the sensor located behind the cylinder? Hey Kirk picked it up in Vernon.
    Thanks for the info.
    Bill
  6. oregonsage 4st Clerk
    Dry Washington
    FX450
    Yamaha DT400 x 2, BMW G310R
    Also, the factory issued some new maps shortly after release....you should have your dealer run it on the MOSS and tune it up. They run much better afterwards.
  7. RDTCU Husqvarna
    '11 630SMS
    Being an 11, he should be good to go. Bill, what are your Ibeat and JD settings? If the problem persists, you may need to throw it on I-beat and get the throttle zeroed.
  8. oregonsage 4st Clerk
    Dry Washington
    FX450
    Oops, for sone reason I read 650 instead of 630.......nevermind
  9. ghte Husqvarna
    Bright, Victoria Australia
    Mate most huskies are slow to spool up when cold. I found that iridium plugs helped immensely. Also a trickle charger is a good ploy.
  10. organ donor Husqvarna
    Berlin
    Mine´s the easiest bike to start (hot OR cold) I´ve ever owned. I never use the cold start mechanism (and don´t even know exactly what it does).
  11. 1lunger Husqvarna
    Bloomfield CT
    Bad gas? Or dirty air filter?
    Edit the bad gas?, just saw fresh 94 oct when reading post to see if fans running all the time, because that's normally what they do when temp sensors STB.
  12. Bill B Husqvarna
    2011 630 TE
    Hello RDTCU
    I don't have ibeat and i don't know the JD settings, if i take it to a dealer i guess they can help me out with that info. does this sound like the right direction i'm going in replacing the temp sensor?
    Thanks Bill
  13. RDTCU Husqvarna
    '11 630SMS
    I've never had to use it either, but I don't usually ride in sub-freezing temps...
    All it does is dump more fuel, similar to a choke.
  14. RDTCU Husqvarna
    '11 630SMS
    It doesn't really sound like the symptoms of a bad temp sensor on these bikes.
    Does your radiator fan ever come on randomly or run all the time?
  15. Bill B Husqvarna
    2011 630 TE
    Started up yesterday barely and let idle maybe 2 mins. Fan came on. Is that normal?
  16. RDTCU Husqvarna
    '11 630SMS
    It came on after ~2 minutes or right away? Big thumpers put out a lot of heat at idle, and I normally don't warm mine up for more than 30-45 seconds in the mornings. What's the temp like up there?
  17. Bill B Husqvarna
    2011 630 TE
    It was around 38 to 40 degrees out. And fan came on after 2 mins.
  18. Bill B Husqvarna
    2011 630 TE
    Hello members
    Just to let you know i put the battery on a charger and gave a little gas and around the third try it fires up! There is a little getting use to it but I am sure it will work out! Bought a temp sensor for down the road aways.
    Thanks for the ideas Guys
    P.S. Can anyone swing me in the right direction, I want to put super moto rims on this bike, is it an easy job?
  19. BarberPole Husqvarna
    Above Boone, NC
    2008 TE610
    XT225
    I'm glad we are discussing idle time to fan run. I have only had a chance to run my bike a couple times before storing for the winter and the fan came on within 2-3 minutes at idle in 40 deg F temps and that has made me wonder if the sensor is reading properly.
    I thought I saw a post where someone did resistance reading on the sensor at various temps. Does anyone know where that thread is? ADV?
  20. mnb Husqvarna
    San Jose, California
    2011 TE310 . . . . 2003 TE610e
    Did he mean 35-40C? That's pretty warm...
