125-200cc New owner wxc250 have questions
Discussion in '2 Stroke' started by Bansheerider29x, Nov 25, 2013.
  1. Bansheerider29x Husqvarna
    wxc250
    Just bought a 95? wxc250 today with a locked engine. Previous owner removed the head and saw no damage on top or on the cylinder. He believes the crank rod bearing is seized. Im curious as to what parts are interchangeable. Can use a cr250 crank by chance? If not where i can order bottom end parts? I already can easily find the top end parts. (im in new york if it matters)
    I have done plenty of rebuilds before but kind of at a loss when it comes to finding husqvarna parts. Also would like to know if anyone has the factory service manual specs on this engine. Any info that can be provided would be great. Thanks, Nick
  2. Bansheerider29x Husqvarna
    wxc250
    Umm anybody out there?
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    check with halls husqvarna.....they have quite a bit for your bike...
    steadydirt likes this.
  4. Motosportz CH Sponsor
    Call a good shop like Halls, Bills, up-tite or whomever is the go to shop on the east coast and start asking questions.
  5. K5PL5 Husqvarna
    Palmyra, PA
    2012 WR300
    You could contact Scott at Toytech if you havent already done so. He may not have everything youd need in stock but hes a heck of a guy and would probably be helpful. (717) 469-9484
  6. Bansheerider29x Husqvarna
    wxc250
    Thanks guys, Halls site seems to have the main information i was looking for. Happy thanksgiving everyone!
  7. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    before you tear it down take a quick look to see if something is stopping it from rotating, a broken gear etc. since it was not in your possession when it happened assume nothing
  8. Bansheerider29x Husqvarna
    wxc250
    The story went that it had a loss of power. It would hit the power band and bog between low and high rpm. The guy dropped it off to a friend to look at, he took it for a ride and after shutting it off and cooling down the engine was locked up. I have a new york state title and plan to be riding this to work some days once spring rolls around again, so im just going to refresh the top end and anything else it needs.
    I started to take apart everything that is needed to get the engine out of the frame. Its about ready to come out but i left my allen keys at work so i had to stop. So far i can look into the exhaust port, the piston is right in the middle of the exhaust port right now. I can see the rings, top of the piston and a little bit of the cylinder. Nothing looks damaged so far.
  9. Bansheerider29x Husqvarna
    wxc250
    Okay im stumped and getting frustrated. The last bolt i need to get out is the swing arm bolt. No matter how hard i beat it it doesnt move at all. I have no access to heat or else i would have heated the shit out of it by now. Im about to get a sledgehammer and beat the living crap out of that bolt. I screwed up the tip of the threads so i can't get the nut back on. Im at a loss and just want this damn engine out. Any kind of tricks?
  10. 2premo Husqvarna
    Northern NV
    any heat helps even a hair dryer, lay it on it's side put a little rust penetrating solution on it and use any heat to pull it in
    sledge hammers tend to do damage as in bending or cracking, break the rust and solidified grease first
  11. Bansheerider29x Husqvarna
    wxc250
    Alright i'll keep spraying it and grab a portable torch. Since there is a hole going through the middle of the entire bolt has anything tried taking a smaller bolt, putting a washer bigger than the frame tube on one end and slide it though with a nut on the other end. Tighten the nut up and making the swing arm bolt pull out if you understand what i mean. Might have a problem finding a high grade small long bolt though.
  12. Bansheerider29x Husqvarna
    wxc250
    Ended up using some heat and was able to get the bolt out. Top end is off, cylinder and piston isn't scored but looks worn. Lower connecting rod bearing is seized, crank bearings feel very stiff and will be replaced as well. Clutch cover/ clutch disc have been removed. Clutch basket is very worn. I cant find any used parts for this bike. If anyone has a crank/rod and clutch basket they would sell me i would be extremely interested.
