250-500cc New Piston
Discussion in '2 Stroke' started by david gross, Apr 6, 2014.
  1. david gross Husqvarna
    New Zealand
    2008 WR250 1984 WR250
    1979 GS750
    Replacing the piston on 2008 WR250 what's the go on seating the new rings , Getting conflicting info some say do nothing others use a scotch bright pad to very lightly score the bore ? .
  2. duey Husqvarna
    2009 wr 250
    2003 ktm xc 2008 ktm 250 sx
    My cylinder at + - 60 hrs I did not touch walls this piston change
  3. shrubitup Husqvarna
    Seattle WA
    deglaze bore with green scotch brite pad and WD40, service power valve, wash all with soap and water, dry, oil the needle bearing/wrist pin with two cycle oil, do not oil the piston/rings/cylinder, install jug, no heat cycles, go ride normal after std warm up.
  4. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    i dont do anything re cylinder unless ive junked it then its off for new nikasil!
    i thought glazed bores only happen if you thrashed it mercilessly from brand new like no runing in procedure?
    anyway install new rings piston torque or tighten everything double check and do a few heat cycles avoid high rpm and lug the motor more that usual, your trying to bed the rings into the bore.
  5. david gross Husqvarna
    New Zealand
    1979 GS750
  6. PowerKord Husqvarna
    Notheast Ohio
    2008 WR 250 Sold
    2014 Sherco SE-R 250
    This has always worked for me.
