New sm 610 owner with questions
Discussion in '610/630' started by frestylmotox01, May 2, 2014.
  1. frestylmotox01 Husqvarna
    SM610
    Good evening all, I just purchased a 09 sm610 with 7700 miles on it. I want to check the cct but am not sure exactly how to, I read a bit and am still a bit confused. Can I just unbolt the middle bolt then the other two then count the clicks?
    Also it has a Leo Vince slip on installed but also came with the stock one. The lv is installed right now, but there is no o2 sensor installed, just a plug screwed in. Is this safe? I'm told it may have had the power up kit, but there wasn't any definitive info, how can I tell?
    Thanks for your help!
  2. Spice Weasel Husqvarna
    UK
    08 SM610
    Yes, then before you re-install it press the release and push the adjuster back.
    Theres a plug under the tank, it will either have a resistor put in it or a small box plugged in. I put the resistor in mine and gutted the original can.
    Also, buy a decent drive chain and sprockets and throw the OEM in the bin, ASAP
    JonXX likes this.
  3. frestylmotox01 Husqvarna
    SM610
    Thanks for the answer.
    Are there any other engine upgrades? maybe a cam change to add a little more power up top? are PCV worth the money on these bikes?
  4. withiam Husqvarna
    NY
    2009 SM610
    Hypermotard 1100 EVO; KLX250SF
    My 2009 SM610 is bone stock except for the power up kit and a LV slip-on. Runs strong. I like the stock gearing too.
    These are great bikes. I'm keeping my eyes peeled for another one. Mine has just over 3000 miles on the odo. She's still has a lot of life left in her.
