TE/TC New TE 250 and TE 125 leaking fork seals
Discussion in '2st' started by be350ka, Mar 30, 2015.
  1. be350ka Husqvarna
    2015 TE 250
    As I sit in the woods waiting on a truck to pick me up (flat rear tire, damn shale) I noticed that my fork seals are weeping. Not gushing, but wet rings after compression. Has anyone else experienced this? The bikes have 2 hours total on each bike.
    I love being in the woods
  2. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    the tubes mite a little rough still clean up under the wiper and seal real good and see if it stops
  3. Cameron Lemon Husqvarna
    New Brunswick, Canada
    2015 TE 300
    2007 KTM 250 XC
    On my 2015 with zero hours (4' of snow still) the tubes were rough, not sure why or what was on them but it took a bit of elbow grease to clean them up.
  4. Aaron platt Husqvarna
    Central Oregon
    17 TX300, 17 FE450
    16 Beta EVO 300
    Both of mine weeped a little bit. They stopped after a few hours, haven't had any issue.
    The shock on my 300 did blow out at about 10 hours.
  5. be350ka Husqvarna
    2015 TE 250
    Good to hear that it stopped leaking. When you say the shock blew out what do you mean. Total loss if fluid?
  6. Aaron platt Husqvarna
    Central Oregon
    17 TX300, 17 FE450
    16 Beta EVO 300
    It lost quite a bit of fluid. It was leaking right at the shaft. I'm not sure what caused it, but it was my excuse to have it revalved.
  7. Kevin A Husqvarna
    '15 TE125
    Former '11 Berg FE390
    Yeah, I was not thrilled with the leaky seals today, but I'm encouraged to hear that it's possible they'll stop. Seems like an oversight on a pretty integral, yet simple part.
  8. be350ka Husqvarna
    2015 TE 250
    Did you contact the dealer about your issue? I'm curious if they would have fixed it under warranty
  9. be350ka Husqvarna
    2015 TE 250
    Kevin, I was less than impressed with my flat tire Too!! Ha
  10. Kevin A Husqvarna
    '15 TE125
    That did put a stop to the ride pretty quickly - maybe you need heavier heavy duty tubes. Do they make something like 10 mil?
  11. Aaron platt Husqvarna
    Central Oregon
    17 TX300, 17 FE450
    16 Beta EVO 300
    I never talked to anyone about it. Just sent it off to Zipty.
    WP is the reason my next bike will probably be a Yamaha.
  12. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    did you all check fork /axle alignment? seems odd to have seal leaks, for sure its not common.
  13. Aaron platt Husqvarna
    Central Oregon
    17 TX300, 17 FE450
    16 Beta EVO 300
    The weeping on the forks could be some residual oil between the dust seal and the main seal left over from assembly. Both of mine were just enough to attract dust for the first two or three rides.
  14. be350ka Husqvarna
    2015 TE 250
    Alignment is fine. Worth a double check. I'll keep an eye on it but it seems strange that two bikes have both fork legs weeping.
