bmasho
		Greetings all,
I'm a newbie with my first fuel injected bike, and first Husqvarna since owning a 1974 250 Mag. The bike is a new (leftover) 2010 TE310 with 12 miles on it that I bought from a private party. It had been sitting for a while.
It came to me with a dead OEM fuel pump which I replaced with one from CA Cycleworks. The new fuel pump now primes as it should when the key is turned on All fuses and relays were tested prior to replacing the pump and all are fine. Given the age of the bike, I did not replace the fuel filter as it appeared to flow ok.
The bike has a strong battery and a good spark, but does not start. Cranks very strong but does not even hint at firing up. Kill button in proper position etc.
Did I overlook something here? Could the fuel injectors themselves be clogged from sitting?
Thanks in advance for your thoughts.
