New to me 2010 TE310, minor problem
Discussion in '4 Stroke' started by Broccoli2, Aug 10, 2012.
  1. Broccoli2 Husqvarna
    2010 TE310
    08 RMZ250, 08 600rr & a few more
    Hi all I finally got a TE. I've been wanting one for quite a while. I've got my work cut out for me.
    I need a workshop manual, I know there is one on this site.. Time to get friendly with the search feature
  2. Coffee CH Owner
    Words fail me. Best of luck with that.
  3. Broccoli2 Husqvarna
    2010 TE310
  4. duggoey Husqvarna
    NSW, Australia
    2010 TE 310
    KTM 690, Yamaha WR200, FGS650(800cc)
    Gives meaning to the term valve slapping...
  5. ghte Husqvarna
    Bright, Victoria Australia
    Did you buy it like that?
  6. Broccoli2 Husqvarna
    2010 TE310
    yep, Not sure why but, yep. Spent $1200 yesterday on the first batch of parts
  7. Freaky Husqvarna
    Kidderminster Worcestershire UK
    2010 TE250 x-lite Race ECU/Injector
    I like the 'minor problem' title!! What caused the damage? Valve broke or piston hit valve?
  8. Broccoli2 Husqvarna
    2010 TE310
    Haha---- Yea hard to show sarcasm in words---- Not sure what happened. I bought it like this. The only thing I know is the kid was flat out on the freeway. I would think the valve stuck then the piston hit it and BLAM....
  9. Freaky Husqvarna
    Oh dear, is the head salvageable? What about con rod, crank and barrell?
  10. duggoey Husqvarna
    NSW, Australia
    2010 TE 310
    I hope for your sake the rest of the damage is minimal. All I know is for these low capacity TE's a Freeway = :(
    Check the decompressor isnt/wasnt stuck on (which causes a valve to open) , I dont know which valve it acts on but Im pretty sure it is only one.
    My TE will do >145km/h (not a typo) but I dont imagine it would be happy to do it for more than for a few 100 metres at a time.
  11. Broccoli2 Husqvarna
    2010 TE310
    nope it wasn't stuck. The one that broke was an intake the decompression (you right is just one) is the right side exhaust valve. i am actually going to use the stock cylinder and just get a new piston cause i'm pretty sure this one with the hole in it is not good... haha
  12. Broccoli2 Husqvarna
    2010 TE310
    Nope the head is bad off that thing is cut into the sides like a knife in butter. I ordered a new head complete, piston, rings, con rod, timing chain, gaskets and water pump. Of course then I read about the high flow water pump, so tomorrow I am going to try and get that one instead. I'm spending tons of money, I am pretty sure they will let me exchange for a more expensive part. Oh and today I was looking at the bike and saw a small puddle of oil under the right front shock.... Guess i will be rebuilding the shocks too. hah a good times, good times....
  13. duggoey Husqvarna
    NSW, Australia
    2010 TE 310
    If you have the dual chambered 50mm type (red anodised fork boltheads) like mine, dont start me on the troubles I have had with leaky seals. Change the fork oil, install new seals and make sure you take about 5mm off the inner seal spring length.
  14. msev1111 Husqvarna
    TXC310
    KTM 500 EXC, Ninja ZX14
    I don't think that many guys are capable of doing what you are doing (i.e., bringing life back to an engine like that.) Good luck.
  15. Phoenix Husqvarna
    Oklahoma City, OK
    2009 TXC 450
    2 Ducs, 14 GG 200, 13 Husa 300
    The silver lining of the situation is that the forks are really easy to work on. lol. We almost have it down to a science!
    The high flow water pump is definitely worth it! The high flow kit just comes with the impeller and cover. It doesn't come with O rings, shaft, seal, nut, etc. so be sure to leave those on order if you can't reuse the existing parts.
  16. Broccoli2 Husqvarna
    2010 TE310
    Crap, Please tell me your not talking about this
    Here are a few more pic's...
    BTW... Why did this guy change out the kick stand.. Is there a problem with the stock one?
  17. Broccoli2 Husqvarna
    2010 TE310
    I forgot to ask... In my last post the top image of the fork top.. Look at the bars clamp. Is that normal? or did this guy replace the upper tripple for some reason..?
  18. Phoenix Husqvarna
    Oklahoma City, OK
    2009 TXC 450
    Yes, those are the potentially leaky forks. Don't panic too much. I think that seal savers help a bit (matter of opinion there) and be careful with pressure washing around the fork seals. Be careful with those little rubber stoppers over the schrader valves too. If you lose them, there is pretty much NOWHERE to buy replacements (I haven't found a source yet). Guard them with your life!! :)
    As for the bar clamp, it looks like the previous owner did a little homemade modification to make 7/8 bars fit into the 1 1/4 mounts. 2008 and up came with 1 1/4 inch bars stock and the clamps in the picture are stock clamps. You can rotate them 180 degrees if you like your bars in a more forward position.
    I think you're really going to like this bike once you have it back together.
  19. Broccoli2 Husqvarna
    2010 TE310
    Phoenix. will do on the forks Thanks for the Heads up...
    The bas thing is weird.. Why would anybody change them? And I would think all the controls wouldn't fit. Unless he changed all the controls.
    To me it looks like he must have crashed pretty bad and bent the bars and clamp and replaced with what he had laying around. The rubber thru the tripple on both side is rotted and cracking..
    Are you sure this bike 2010 TE310 came with 1 1/4 bars and not the 7/8?
  20. Rocknroll Husqvarna
    Did you get it running??
