new to me tr650 2013
Discussion in 'TR650' started by shorthair, Dec 19, 2016.
  1. shorthair Husqvarna
    tr650 2013
    85 vmax, 09 vmax, 13 roadglide.
    hey everybody, i only have one question ( so far ) burning at my mind..whats the easiest way to tell if my tr650 is restricted?..i just bought it right after our last snow storm and havent even driven it yet..thanx alot..
  2. CarstenB Husqvarna
    NL
    F650GS Dakar
    take the seat off and peak through the gap between airbox and engine. You may need a flash light. You will see the throttle body and on the left side the cable drum. Either check if the throttle cable is hooked into the outer drum (unrestricted) or the inner one (restricted) or pull the throttle to full open and check if the metal tab on the throttle drum hits the aluminum tab on the throttle body. If it does it is unrestricted.
    PaulC and Mark_H like this.
  3. glitch_oz Husqvarna
    AUS
    Strada
    There are no restricted versions in the US, only Australia and a few EU-countries. Using the term "driven" rather than ridden indicates some EU/UK?-origin.
  4. Ziggy Husqvarna
    Melbourne, Australia
    Terra 650
  5. shorthair Husqvarna
    tr650 2013
    info worked perfectly,found out in seconds, thanx alot brother.
