erock
Hi,
So here's my scenario, any help would be appreciated.
Its a 2014/13 CR125, and as I was stripping it down for a good clean and lube, I was attempting to reconnect the clutch cable by holding the piece that connects the clutch cable to the lower-end, with a pair of pliers and I guess I put too much counter-clock wise pressure on it and it went past where it should have stopped. Okay, so I attempted to turn it clock wise to get to where I needs to be, and then attached the clutch cable. It starts and engages in all gears, but I seems to be lacking power, the hit is gone.
I haven't split cases before so I can't really visualize what I jacked up, and what needs to happen to get the power back.
My feeling is that the clutch isn't releasing all the way, almost as if I was riding with the clutch pulled in a little. Not sure if that's even possible.
Any insight?
Any insight?
