No reed valves on a 73 250CR??
Discussion in 'Vintage/Left Kickers' started by spaceace182, Sep 19, 2016.
  1. spaceace182 Husqvarna
    Modesto Ca
    1973 250cc CR
    Took the intake off of my 73 250CR and there is no red valve? So how does this engine work with no reed valves??? Looked in the parts manual and it shows no reed valve or reed block. Can someone explain to me how this is possible?
  2. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    How does a 2 stroke chainsaw engine work? they don't have reeds! and you don't have to have them, but they sure help preformance
  3. DPete Husqvarna
    Farmington, Ca
    1972 WR250 76' 360 WR 18' FE 450 17
    Yam wr250r - Suz DRZ400s - 2 Harleys
    The piston skirt is the valve, reed valves didn't exist on early dirt bikes
  4. jimspac Husqvarna
    Connecticut
    86 400WR, 82 Montesa Cota 349
    Reed valves were introduced on Yamaha Enduro and MX models in 1972. Husqvarna first used reed valves with the MAG 250CR released in 1974.
  5. Bigbill Husqvarna
    '83 250wr
    0 right now
    It's a piston ported engine. The first trick we did was to cut 1/8" off the bottom of the piston skirt. This changed the port timing. We raised the exhaust port and lowered the intake port. This gave the engine a longer duration on the intake and the exhaust port opened sooner.
    Just for ha's, ha's we took a '71 Suzuki TS 125 and cut the bottom of the piston 1/8". Advanced the timing a tad. I put kx80 rear shocks on it so it had some suspension. We beat kx80's in the straights. You should of heard the kids complaining, egos were hurt in this process. Just when they thought they had game a POS looking antique bike beats them. My point was to make the kx80 kids ride harder nothing is a given. You have to up your game to be a head. Again no reeds. Nothing wrong with old technology it's good for a few laughs in the high tech world.
  6. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    early pp engines had a bad habit of filling up with fuel (loading up) if too much throttle given at too low rpm / high gearing. it was common to see guys on the side of the track holding the throttle wide open with the bike barely running and sounding like the choke was on. eventually it would clear (or foul the plug). the reed valve effectively prevents this occurring by shutting the fuel supply as soon as the crank pressure changes.
  7. SteveJ Husqvarna
    New Mexico
    1970 400 Cross, 1983 500 CR
    84 Honda CR500R, 81 Honda CBX,
    The intake is timed by the piston skirt, when the piston is coming down, the piston skirt closes off the intake passage between the crankcase and intake manifold. Pressure is then being created in the crankcase by the reduction in volume due to the downward travel of the piston. When the piston is low enough, the top of the piston uncovers the transfer ports and the fuel/ air is blown upward through the transfer ports into the cylinder. The piston then begins to rise. Volume increases in the crankcase due to the upward travel of the piston and a vacuum beings to develop in the crankcase. Once the piston skirt uncovers the intake port, the vacuum draws the fuel/ air mixture into the crankcase and it all starts again. The longer the piston skirt, the slower the timing and lower the rpm the engine makes power at.
  8. Bigbill Husqvarna
    '83 250wr
    0 right now
    This was proven at the country fairs in speed cutting with the Husqvarna saws. The 100cc saws were animals. I set the rakers for pine at .090" per tooth. I did eight cuts, bored two holes straight in, in 17.5 seconds.
  9. spaceace182 Husqvarna
    Modesto Ca
    1973 250cc CR
    Thank you all who replyed! Great explinations! I am now educateted!
  10. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    edjamacated...get your spelling right:naughty:
    justintendo and ajcmbrown like this.
