No Spark
Discussion in '610/630' started by Shaggy33, Sep 21, 2010.
  1. Shaggy33 Husqvarna
    worcester
    I have rebuilt my 1999 610 after engine overhaul but can't seem to get a spark.
    I have done all the checks, wiring, earths etc and can't imagine it will be a fault coil etc as it ran perfectly before dismantling it.
    I have read that the stator can be bolted in the wrong position inside the engine cover and think I may have done that.
    Question is what is the right position or is it obvious???
    Cheers
  2. TheDutchman Husqvarna
    Watsonville, CA
    Can you take a pic of how you installed it?
  3. Shaggy33 Husqvarna
    worcester
    Thanks for reply
    Will take pic tomorrow morning. Draining the oil over night (it's 10.20pm here!)
  4. Shaggy33 Husqvarna
    worcester
    no spark (pic of stator position
    here is how I have fitted stator, is this correct?
    Cheers
  5. TheDutchman Husqvarna
    Watsonville, CA
    If I remember correctly (I tried to verify but had no luck) the stator has to be turned clockwise one screw worth (about 90 degrees).
