Numbers, Exhaust, Porting early CR250
Discussion in 'Vintage/Left Kickers' started by Go_Navy, Jul 31, 2010.
  1. Go_Navy Husqvarna
    St. Louis
    I have a CR250. It has no numbers anywhere I can find. Looks like a 1978 to 82 maybe. I can't figure it out. I have check the bottom. No hole for id plate on top. I don't have a clue.
    If it is a late 70's model, what is the best pipe for vintage racing. Vintage iron offers the retro rocket, butr they are for the MN frame I beleive.
    Also, what about porting for vintage racing?
    Thanks
    timothy.g.lancaster@doc.mo.gov
    (314) 412-4510
  2. tommie d Husqvarna
    Kansas
    Twenty one and counting
    Two Honda's
    Pictures???????
  3. Northern Husky Husqvarna
    Canada
    l belive factory replacement cases had no #s stamped on them.
  4. Go_Navy Husqvarna
    St. Louis
    Here is a picture. Can anyone tell what year this might be.
  5. oldhuskychuck Husqvarna
    Denver Co
    77-79... no dog leg clutch lever, and a magnesium flywheel cover. in 81 the CR,s started to change those things.
  6. Go_Navy Husqvarna
    St. Louis
    Do you know where can I find an aftermarket pipe for this model, or a good stock pipe? I have the ML frame.
  7. oldhuskychuck Husqvarna
    Denver Co
    id have to check,i may have a stock pipe. for a 79
  8. alaskan husky Husqvarna
    alaska
    my 78 CR 250 HAS AN 8 SPLINE COUNTER SHAFT, WR 250/390 HAVE 12, (1980) IF IT TURNS OUT TO BE A WR, SAVE EVERYTHING AND BUILD A WR 390! PERFECT MOTOR FOR US OLD FARTS THAT REFUSE TO GROW OLD!
  9. Go_Navy Husqvarna
    St. Louis
    Thanks! This is fun. My first foray into vintage.
  10. Go_Navy Husqvarna
    St. Louis
    I checked, my engine has 12 spines on courntershaft. Does that make it a WR? Do 250 and 390 top ends interchange on this motor?
