125-200cc NW or Sea Level 125's
Discussion in '2 Stroke' started by Poopy, Mar 20, 2010.
  1. Poopy Husqvarna
    Kamloops, BC
    WB165
    Where are you at for jetting with the stock carb? I will admit if there is one thing i really suck at...its gotta be carbs.
    Mine is an 09 wr125.
  2. pvduke Husqvarna
    ... on the gas...
    tripple-hondo hoosk...
    in socal near the water the air here is fairly dense in spots. my starting baseline was
    AS- stock w/ a tweak here or there
    PJ- 32.5
    N- #3
    M- 460
    too lean for sustained w/o with a small hitch on roll on from mid speed circuit to main circuit.
    current-
    AS- 1.5 -2 out
    PJ- 32.5
    N- #4
    M- 480
    oil- motul 710 2t 50:1, almost no smoke and little if any drool.
    this works from 3000' to 6000' . it's clean and crisp enough in lock to lock ugly stuff and after long decents w/o being too lean for long open uphill stuff. hi dez i use 490 main, low dez 500 main.
    ymmv
    search "how a carburetor works" for a visual of the circuity...it's in the efi/carb section.
    http://www.cafehusky.com/forums/showthread.php?t=8039
  3. Poopy Husqvarna
    Kamloops, BC
    WB165
    Awesome thanks so much. I've been searching all over for a good carb how to and it was here all along.
    :applause:
  4. pvduke Husqvarna
    ... on the gas...
    yer welcome. :)
  5. Poopy Husqvarna
    Kamloops, BC
    WB165
    Ok it seems to be getting close...I just have a bit of a stutter before it gets into the power valve. Im running Walts springs that open the PV at 6200 ish, and it feels almost like hitting a rev limiter until I crack the throttle open a bit more. This is between 1/8 and 1/4 throttle. I am going to go play with the air screw. But would what im describing be a rich or lean condition?
    Im new to 2 strokes too....:D
  6. pvduke Husqvarna
    ... on the gas...
    1/8 - 1/4
    how's your off idle response?
    if it falls on it's face try 1/4 turn in on the AS to fatten it up.
    then retry. if turning the screw in helps try raising the needle one tick to richen to make a smoother tranny from one circuit to another.
    i dont know our baseline so im guessing here...
