odo pick up magnet
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by skid, May 17, 2011.
  1. skid Husqvarna
    NH
    I have a watchdog enduro computer that I'm mounting up to my 08 cr 144. as luck would have it the caliper hanger is predrilled and threaded so you can screw in your odo pick up and the disc has a hole for mounting the pick up magnet. Thats the good news ....
    The bad news is ....
    There is an enduro this Sunday. Maybe Halls can get me a pick magnet two dayed if they have one. If that is not the case does anyone know of a crossover. I will check with the local jap dealers. If all else fails I can drill the disc and epoxy a small magnet that came with the watchdog. A magnet that pops right in would be a bit more clean though ....
  2. dfeckel Husqvarna
    Medford, NJ
    I've used a magnet and circlip made for a KTM with success. I think I needed to slightly relieve the hole in the Husky disc to get it to fit, but it worked fine.
    boltnnutz likes this.
  3. skid Husqvarna
    NH
    halls has one coming out two, will get it friday.If it doesn't show up maybe a ktm dealer close by will have something. thanks for the tip feck
