TE/TC OEM Fork Spring Rate Chart USD 4860 4CS
Discussion in '2st' started by robertaccio, Feb 19, 2015.
  1. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    2-19-2015 12-41-15.png Even though this is based on the OEM 4CS configuration and mine's not, I went with these numbers to get the bike balanced per the OEM. I use .48 Kg/mm fork springs.
    hawaii-rider likes this.
  2. decooney Husqvarna
    NorCal Folsom CA
    2015 FE 501S
    2014 Yamaha Super Tenere
    Thanks robertaccio,
    using your chart for the 4CS forks on the smaller and lighter TE250, it shows the stock 4.4 N/mm fork springs are correct for my weight. Using the specs in the new Husky 2015 501 manual, the next level up 4.6 N/mm fork springs are correct. The reason your chart won't apply in my case is the newer Husky TE250 is 230lbs dry weight. The 2015 FE 501S is 251lbs dry weight. Looks like I'll end up with 4.6 fork springs.
  3. robertaccio Husqvarna
    San Diego, Ca
    you got it just plug in your 501 numbers and you got got the idea!! this chart was put together from the te250/300 spring spec
    Ive got .48 Kg/mm fork springs in my TE300 for example
