Ohlins ITC lengths for '83/'84 WR/CR
Discussion in 'Vintage/Left Kickers' started by Kartwheel68, Aug 4, 2012.
  1. Kartwheel68 Husqvarna
    Newnan, Georgia
    I did a search and saw some discussion of the different lengths of ITC shocks on the WRs and CRs. Someone mentioned that the shocks are all the same, there are different thickness internal spacers to set the length for the WR and CR applications. I have an '83 175WR with the Betor ITCs, which are blown. I might later take them apart and see if the Ohlins internals will fit, but in the mean time I bought some Ohlins ITCs for a CR on eBay for $157. The 175s had less travel (9.8") than the 250/430 (10.6"). I want to keep the WR low as I have an '82 XC that I will keep set up with long travel.
    Does anyone know for certain what the thickness of the WR, CR internal spacers are, and what the overall length of the two shock specs were? Works Performance lists their application as 18.5" for a CR with ITCs and 18" for a WR. Does that sound right?
  2. Kartwheel68 Husqvarna
    Newnan, Georgia
    I bought CR length Ohlins on eBay, I need to know how long the WR shocks were.
  3. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    I have these all stock Huskys. 1) 83 250XC which is the same suspension as the CR has ITC 18.5 c-c, 2) 82 250WR has 17" c-c Ohlins piggy back, & 3) 82 430CR has 17.25 c-c Ohlins piggy back. I believe the 83-85 ITC have different length bottom swingarm mounts, that's
    how they changed the WR & CR/XC lengths....Husky John
  4. street2dirt Husqvarna
    World's Most Famous Beach
    12 TXC310, WR300, 85 125WR, 82 175XC
    BMW G650X
    And I just checked the 85 125WR, they are 18.25. ITCs and yes the swingarm mounting locations are different
  5. Kartwheel68 Husqvarna
    Newnan, Georgia
    Ah, so the '85 WR has 18.25" shock length and the CR/XC is 18.5", and they moved the lower shock mount on the WRs?
  6. Kartwheel68 Husqvarna
    Newnan, Georgia
    I'm going to go out right now and measure the Betor ITCs and see how long they are. These CR Ohlins I got on eBay for $157 are in perfect working condition except the bottoming bumpers are gone.
  7. Kartwheel68 Husqvarna
    Newnan, Georgia
    The Ohlins ITC shocks I bought on eBay that were said to be from an '83 CR are 18" and the Betor ITCs that came on my '83 175WR are 17.75". I put the Ohlins on the bike and the rear end is slightly higher (obviously) but not much. I think with the slightly longer shocks and the stock 9.8" travel front forks it might end up being a pretty good setup for tighter cross country courses.
  8. SA63 Husqvarna
    Glasshouse Qld, Australia
    84 510, 500 auto , 86 510
    i have rebuilt several sets and they also come with different spacers inside depending on model. The longer the spacer the shorter the shock, so they can be fine tuned to what you want.
  9. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    dont frget you can adjust the fork length with wr vs cr damper rods and sliders
  10. Kartwheel68 Husqvarna
    Newnan, Georgia
    I will probably shorten my '82 XC forks to 11" travel to sharpen the turning by putting a rebound spring in it. I'm only 5'7" so I want the '83 WR to retain its lower seat height for tighter courses and keep the XC long travel for open courses. The 18" Ohlins do make the WR a little taller at the back, but that should also help turning. I'll try them as is before I shorten them to 17.75", the length of the Betors that it came with.
  11. jimspac Husqvarna
    Connecticut
    86 400WR, 82 Montesa Cota 349
    You can shorten with a 1" long PVC pipe length under the head of each dampening rod
  12. Kartwheel68 Husqvarna
    Newnan, Georgia
    I will use a spring under the head of the damper rod instead of a spacer, I have never been happy with the Husky forks top out issue. I can shorten the fork and get a real top out spring at the same time.
  13. hva-factory CH Sponsor
    uk
    Husqvarna 510TE , 300WR Etc...
    When you Disassemble the shocks, there are spacers between the seal head and the piston. You can remove or add to these to change the shock overall length. With the ITC shock, they have a piston that enters a hole to give a hydraulic bottoming device. I remove these (or actually, it is easier to leave it in position and remove the alloy sleeve that the piston enters) and use a conventional Ohlins bump stop on the outside of the shock rod. The thinking here is that if you compress the shock really quickly - the ITC device hydraulic locks - which is why the shafts are often bent, and why Ohlins latest products have reverted to the good old - old fashioned bump stop. Also, you often find the 'topping - out' 18m/m dia spring inside is broken. Replace this spring before you re-assemble. ITC's ran 7.5w oil...
    Andy.
  14. firecrackerkid Husqvarna
    Grand Coulee, Washington
    78 390 OR, 84 250WR, 83 175WR
    20 miles of whoops +350lbs = bent shaft. At least now I know why. Looks like the are going back to Drew for an update.
  15. Chayzed Pilot Husqvarna
    So Cal
    2004 TC450,1978 390CR,1983 430 Wr
    A gaggle of them
    From my limited experience with Ohlin's. The hydraulic lock "may" contribute to the shafts bending but there are also side loads during the operation of the shocks. The real problem is the shafts are extremely soft. I had to straighten one with a press and they are like butter. Chuck Curnutt found this out in his early development of long travel shocks and hardened the shafts on his shocks. It is very, very hard to bend a Curnutt.
  16. Joe Chod Husqvarna
    upstate NY
    drew uses old fashioned bump stops on ITCs instead of the washer thin one with the 4 slightly raised "Nubbins"
  17. GaryM Husqvarna
    Austin, Tx
    1981 430cr second 430 CR 500cr
    1981 490 Maico
    My question is a bit different. So I have 3 sets of ITCs here - all seem to be off WRs. Not sure yet? Have not worked with these yet. So what is the true shock shaft travel on each shock. This is so I can tell what space limiter is in place inside each pair before I have to disassemble shock to tell.
    Purpose? Why? As I understand even with shock limiter removed from ITC it will not match the shock shaft travel of the 81 or 82 year piggyback Ohlins. The travel was gained on the different mounting angle on 83s? These are my questions.
    Because I would like to put one pair on an 81 82 frame and use the others on 83 84 frames in future. Using shorter mount eyelet on shock for 81 frame.
    So did Kartwheel answer this question completly in first paragraph ?
  18. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    note the ITC's have a longer lower mount length as well.
