Oil capacity ?
Discussion in '4 Stroke' started by husky570, May 19, 2009.
  1. husky570 Husqvarna
    Oregon
    Hello I have a 2002 TE 570, and whenever I change the oil I check the level with the phillips head screw on the side case , it will start weeping oil out after 1 quart of oil, despite the manuals stated capacity being over 1 quart-so whats going on?? How much does this motor take when you do a oil change?
  2. sdc23_99 Husqvarna
    cnnecticut
    Its best to measure the recomended amount of oil and add it. Itwill also make a difference if you are not changing the oil filter, less oil.
  3. Huskybloke Husqvarna
    maitland AUST
    i agree with sdc23_99 measure it up and put it in same thing happens on my 05 te 510 better off to make sure of the amount
