oil colour
Discussion in '610/630' started by MotAd, Apr 12, 2013.
  1. MotAd Husqvarna
    London
    SM701
    2009 Triumph Daytona 675
    hey fellas. i run the standard 10-60 fully synthetic in my 610 and as we know the oil is red in colour. after a few hundred miles the oil goes a dark red/brown and i've been told that this could be because the piston rings are wearing and carbon is getting in to the oil. is this nonsense? the bike's got just over 10,000 miles on it now and i change the oil + filter every 1000-1500miles.
    toying with getting it taken apart and checked out and then while they're at it doing the big bore kit & high comp piston.
    cheers :)
  2. RDTCU Husqvarna
    '11 630SMS
    If it's got a wet clutch, the oil WILL get dark...
    What brand oil?
    The 10w50 Castrol RS racing syn I run in my 630 is gold going in and black/gray coming out, and I get about 2000 miles on it before I start feeling it in the shifts.
  3. Mike-AK Husqvarna
    Alaska
    2012 TE 310
    The litmus test for bad rings is a compression test. If it's got good compression I would not worry about it if the oil is darker in colour. Now if it goes darker in color, that is a different matter. In that case, I would sell it and buy a new bike immediately. :D
  4. MotAd Husqvarna
    London
    SM701
    cheers chaps. i would say from the general pull of the motor it's got good compression still. i'm using motul 7100. this is the first bike i've used fully synth with. with my previous bikes the oil always came out black and was never an issue. it's just something someone said to me that got me curious.
  5. ghte Husqvarna
    Bright, Victoria Australia
    I would recommend the Motul 5100 semi syn. You do not need the expense of the 7100 fully syn imho. The 610/630 are not really pushed too hard and a semi can if fact be a little better for this type of motor.
  6. JonXX Administrator
    Bill's Motorcycles Plus
    360CR 360WR SM610 TC450 TXC250 TC250
    Hondas, Harleys, Yammys & a squid
    If lubricating oil in a recirculating system doesn't get dark, it's not performing its primary function, to carry dirt away in suspension.
    nickterc and McKay like this.
  7. BiG DoM Husqvarna
    Precisely.
  8. MotAd Husqvarna
    London
    SM701
    Cheers for the schoolin fellas :)
