oil dripping...carb problem? please help
Discussion in 'EFI/carb' started by eric125, Aug 20, 2012.
  1. eric125 Husqvarna
    Mass
    2002 wr 125
    2005 yamaha r6
    2002 husqvarna wr125 all stock
    i just recently replaced the o rings on the cylinder head and cleaned everything up since i had a top end done a few years ago but havent riden much at all. i got a ngk iridium plug and also am going to pick up some new packing to replace the pipe (since i dont think its ever been done, i am second owner). but my problem is that were the pipe and the exhaust meet by the air box i drip a left over oil, and i dont feel this should be right. i know you need oil to lube the top end but i think this is a little much.. ive checked the exhaust valve system as well. i havent started the bike since ive cleaned the head and the exhaust valves, and im going to repcak the exhaust this week. but i heard perhaps its a carb setting too. i took the carb apart and saw the main jet was 400.. should that be different and or can i adjust the settings on the outside of the carb.... its a mikuni tmx. and im also looking for aftermarket idle knobs and choke knobs for this carb.. any good part websites ?
    thank you
