oil leaking out of air filter
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by Kekumulaau, Sep 22, 2012.
  1. Kekumulaau Husqvarna
    kaneohe
    2012 TE 511
    kawasaki KX 250
    can some one tell me why does oil comes out of air filter box and whats the fix 2012 TE 511
  2. OlderHuskyRider Husqvarna
    Austin, TX
    Kwaka KLE, HD FXDWG
    Run less oil in the sump, there are several post in the 4 Stroke section that say that the 511 is quick to blow excess oil out the breather and into the airbox, the only solutiion being to run less oil in the sump.
  3. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    When refilling your oil level, make sure it barely touches the bottom of the sight glass. Run your engine for ten minutes to heat the oil, recheck oil level to make sure that it is at the very bottom of the sight glass. :)
