TE/TC Oil used
Discussion in '2st' started by MyersAvionics, Apr 14, 2015.
  1. MyersAvionics Husqvarna
    US
    2017 KTM 450XC-F
    I have a 2014 TE250 and i'm curious to know what premix and engine oil everyone here uses.
    At first, i used Maxima Castor 927 for my premix and Cross Power 2T for engine oil. I then used the Cross Power 2T for both the premix and engine oil and noticed zero splooge coming out of the pipe at all. Ran quite well, but i couldn't tell too much of a difference besides the 927 smells better.
    I was just surprised that the book calls to use the Cross Power 2T for both the engine oil and premix.
    What do all the experts on here use?
  2. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    That must be a misprint or redundant. Two stroke oil is not designed to protect your gearbox and clutch!:eek: Unless there is another page that recommends the transmission oil.
  3. MyersAvionics Husqvarna
    US
    2017 KTM 450XC-F
    I thought it was quite fishy. I would think Top Speed 4T 15W/50 would be accurate.
  4. swtwtwtw Husqvarna
    Apple Valley, CA
    2014 TC 250
    927 at 44:1, 50/50 race gas, 50/50 ATF Type F and 5w30---42 pilot, stock needle middle clip, 165 main
  5. MyersAvionics Husqvarna
    US
    2017 KTM 450XC-F
    What i keep seeing a bunch of is the Rotella T6 and the Mobil Type F ATF. Thinking of trying the Mobil as i change the oil every 2hrs as it is. Anyone else try either of these?
  6. PC. Husqvarna
    Beaverton, OR
    CR165 & CR144
    KTM500
    In my smokers I use Delo 15-40 (rotella competitor) for trans oil and change it every 20-25hrs. I've got 175hrs on my CR165 and the bottom end has never been opened. My clutch is getting tired, but 175hrs will do that regardless of oil type.
    For premix I've used Klotz R50, Torco Gp7 and Amsoil Dominator (all at 40:1) without issue. I recently switched to Lucas semi-synth premix which was recommended to me by a trusted motor builder @ 32:1. The Lucas has a low flash point and only costs $28/gallon.
  7. swtwtwtw Husqvarna
    Apple Valley, CA
    2014 TC 250
    Just a note it has to be Actual Type F, not a universal type F. Wal Mart brand is fine as is their oil. I change my oil often, it is cheap, but could go longer between changes for sure. One can run ATF type F straight in the gearbox too, it is great for the clutch and I have not had a trans failure, going back to when I was kid racing flat track.
  8. BDHANSON Husqvarna
    Southwest Washington
    2014 TC250
    50:1 motorex with JD jet kit. Motorex in the trans as well
  9. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    hows the spooge factor with the lucas
  10. PC. Husqvarna
    Beaverton, OR
    CR165 & CR144
    KTM500
    Not sure yet. I have about 2 gals of amsoil gas to burn before I make the switch.
    Should be low though due to the flash point.
  11. be350ka Husqvarna
    2015 TE 250
    I've been using the Bel Ray H1R at 44:1 and it doesn't spooge much if at all. Liking it so far, but it is pricey.
  12. kitcat Husqvarna
    TE300
    I've just got myself a TE300 and the manual says 60:1. I managed to get a good deal on the Bel Ray H1R and on the back of the bottle it says to mix at 40:1. Any thoughts on this? I'm still running it in but will use it for part hard dusty trails and part road use. Cheers
  13. be350ka Husqvarna
    2015 TE 250
    I called Bel Ray about their oils and was told that anything from 32:1 to 60:1 is fine. 44:1 came up more than once in the conversation.
    kitcat likes this.
  14. Colo moto CH Sponsor
    La Jara, Colorado
    7602racing.com
    I'm using the same Lucas in my 300. 32:1 mixture. Minimal splooge at the cylinder head/expansion chamber area. No splooge at pipe junctions or end of the stinger.
  15. hawaii-rider Husqvarna
    Graham Washington, Fort Moose
    2018 TC250, 2015 TE300
    04 CRF-270x, 95 CR500, 93 CR250 etc
    Oil threads...YIKES....you asked.
    Engine?
    Shell Rotella T blue jug (synth) in ALL MY BIKES - vintage to modern, two or four stroke.
    Premix:
    32:1, Amsoil Interceptor - all my smokers
    from the 1973 Honda CR250 to my 2015 Husky TE300 and a CR500 and 250 in between and sandwiched by a '81 YZ465 and its brother a 1982 IT250.
    HR
    lankydoug likes this.
  16. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    i have noticed the least amount of shavings running the t6 shell rotella blue jug...good stuff. i run it in all bottom ends. i used to use amsoil mc oil but the rotella is much cheaper.
    Tinken likes this.
  17. racemx904 Husqvarna
    owenton, ky
    2014 Beta 350RR & 1986 430XC
    Rotella blue jug I every bike cheap, easy to find and no failures...
    Yamalube 2r.... All the name brand oils are good but you should pick one and stick to it
  18. HS507 Husqvarna
    NE Ohio
    Te 300
    Yz450,crf150r,crf100f,crf50f
    Interesting, you mix atf with oil 50/50?
  19. HS507 Husqvarna
    NE Ohio
    Te 300
    I guess im asking because several people on this chat site says never mix types or brands but ive alwats considered it. I use dex merc atf presently, although last night i drained and added Motul cause i found a full bottle on shelf. I never mixed yet. Is it to get best cusion for gears (oil) and buttery clutch (atf)?
  20. justintendo klotz super techniplate junkie
    your last question is why i stopped using atf, i get a noticeable difference if debris on the magnet using engine oil, especially rotella. im not very hard on my clutch, but it still fells good, with no drag. when i did use atf, it was type f, which is 20w. most atf oils are around 10w.
    its probably best to keep using the same oil, once the clutch fibers are impregnated with it instead of using whatever is around.
