oil
Discussion in '4 Stroke' started by novice, Nov 28, 2009.
  1. novice Husqvarna
    Essex UK
    What oil is prefered for 4t Huskys?
    A simple thread, with oil changes so regularly, is it important to use premium fully sinthetic oil?
  2. ken510 Husqvarna
    Washington State
    You'll find that this is a never ending discussion. Bottom line, use a good quality motorcycle specific oil. If you can't find 10w-60, 15w-50 is a good alternative. If you don't want to go full synthetic, go blended. As long as you change the oil regularly, your motor will be happy. AGIP, Motorex, Maxima, ELF, Spectro, Motul...You can find some good deals on line.
  3. john01 Husqvarna
    Powhatan VA
    I use the Rotella in the white jug.
  4. jmetteer Husqvarna
    Woodland, WA
    TXC300 CR125 CR144
    WR250F, TRANSALP
    So do I, changed regularly. :thumbsup:
    Later,
  5. Wadman Husqvarna
    south carolina
    I use Rotella 15w40 dino oil. This oil works great in any motor. Dont get caught up in all the oil hype. Its silly to buy that high dollar oil if you are going to change it often.
  6. wulf22 Husqvarna
    Utica, NY
    Big thumbs up for Rotella! Used it for years in many applications from my 4t Yamaha snowmobile, cars, lawnmowers, road bikes and of course my Huskys.
  7. ghte Husqvarna
    Bright, Victoria Australia
    By changing rotella regularly do you mean after every ride, just trying to figure the time/value for money angle. If it needs changing much more frequently than say a top of the line Maxima/bellray/motul etc. where is the value given its total package is not as good in the protection department. I do agree that there needs to be a happy medium. For instance my mate only uses Motorex for his (KTM). At 110 bucks for 4 litres and changing out his oil every 3rd. ride I can see him getting the value his oil has in longevity-which you pay for say against a motul here for 70 bucks.
  8. Wadman Husqvarna
    south carolina
    I think everyone likes to brag about how often they change their oil but the deciding factor should be how you ride it. If you race it and hammer it all day long then I would change it after the race. For casual trail riding with moderate revs then I think about every 200 miles is fine.
  9. highdez1981430cr Husqvarna
    Yucca Valley,Ca.
    What weights does the Rotella oil come in?
    Isnt this a diesel oil?
    I think i saw this in walmart the other day.
    What is the advantage in running diesel oil other than it having a higher TBN?
  10. cptseawolf Husqvarna
    Ontario
    cheaper, good detergent package, not energy conserving...so no clutch slippage..., meets a zillion standards
    oh yea and its cheap
  11. john01 Husqvarna
    Powhatan VA
    Yes Walmart carries the Rotella. We change ours about every 10 hours or so which is usually 3 rides. Hey I run the same oil in my Ford SD trucks and I have 180K in one and 144K in the other. In the bikes we get no clutch slippage. Rekluse reccommends the Rotella with the clutch kits. As cptseawolf said "oh yea and it's cheap". Not only is it cheap it works. I run the Rotella in the white jug 15w-40.
  12. 440rev Husqvarna
    IL
    I did a bunch of research on oil here it is. I also posted stuff for oil filters if u have street bikes.
    This was from a email from someone @ shell
    We recently ran the JASO MA friction test on Rotella T with Triple
    Protection 15W-40, Rotella T Synthetic 5W-40 (CI-4) and our soon to be
    introduced (within the next 2 months) Rotella T Synthetic 5W-40 CJ-4.
    All three oils passed the wet clutch friction test. Rotella T Synthetic
    5W-40 (CI-4) has more than 1.2% ash (JASO MA spec limit) so it can not
    be classified as JASO MA. However, Rotella T with Triple Protection
    15W-40 and our soon to be introduced Rotella T Synthetic 5W-40 CJ-4 do
    meet JASO MA."
    If you have any additional questions please call us at 800-231-6950.
    Thank you for your interest in Shell products.
    Richard Moore
    Staff Engineer
    Shell Global Solutions (US) Inc.
    Westhollow Technology Center, PO Box 4327, Houston, TX 77210, United
    States of America
    http://www.bobistheoilguy.com/forums...931332&fpart=4
    API rating -- JASO MA requires SG, SJ, SH, SL or SM. Rotella 15W-40 Triple Protection is rated SM so it meets JASO MA.
    o Suflated ash -- JASO MA requires no more than 1.2% of mass. The new Rotella 15W-40 rates 1.0% of mass for suflated ash. Therefore, it meets JASO MA.
    o Phosphorus -- JASO MA specified a range of 0.08% of mass to 0.12% of mass. A virgin Blackstone analysis I saw showed 989 ppm of phosphorus, or 0.0989%. It meets JASO MA.
    High Temperature High Shear -- JASO MA requires 2.9 mPa-s or better. I read elsewhere the new Rotella 15W-40 has a value of 4.1. It meets JASO MA.
    http://www.kawasakimotorcycle.org/fo...oil-sample.jpg
    Harley Davidson specs 15w40 HDEO oils as their second choice for years. The HDEO specs should be what you look at versus the JASO. IMO
    (Heavy duty engine oil)
    http://motorcycleinfo.calsci.com/Consumables.html
    http://motorcycleinfo.calsci.com/Fil...tml#OilFilters
    http://motorcycleinfo.calsci.com/FilterXRef.html
  13. ghte Husqvarna
    Hi Richard Moore ( I bet the girls had fun with that handle) What is the Rotella equivalent in Australia. I do not think we get the Rotella brand but is Shell flogging it here under a different name?
    Cheers Mate.
  14. oneal Husqvarna
    uk
    1999 wr 250 returned home.
    07 TE 450 2005 TE 450 1999 CR 125
    Does anyone know the european name for rotella has ive never seen it in the uk.
  15. Motosportz CH Sponsor
    I have been using Amsoil fully synthetic motor oil and 2 stoke oil and really like it. Works well.
  16. jmetteer Husqvarna
    Woodland, WA
    TXC300 CR125 CR144
    WR250F, TRANSALP
    Looks like the Shell Helix Diesel Super is the 15-40 heavy duty diesel oil (white bottle). And the Shell Helix Diesel Ultra is the 5-40 "synthetic" (blue bottle).
    I am not sure if the formulation is different though.
    www.shell.co.uk
    Later,
  17. Wadman Husqvarna
    south carolina
    Ill say it again, dont get caught up in the oil hupla, just run the 15w40 rotella and change at a reasonable interval and have fun riding.
  18. 2whlrcr Husqvarna
    Dubuque, IA
    Don't get hung up on Rotella either. Any name brand major oil company 15w-40 is going to do a good job.
  19. wersmokin Husqvarna
    Houston, TX
    1994 WR 350 (sold)1998 TE410 (sold)
    What would anyone suggest using a certain type of synthetic oil on a 2000 TE410? Would it be the same as the new husky's? I had been using Mobil 1 for years and never had an issue. But since I have been more involved I have heard different stories on how you should only use motorcycle oil, and such. Since there are different additives and what not.
