On Coolant and Antifreeze
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by vintageveloce, Jan 5, 2012.
  1. vintageveloce Husqvarna
    Southern California
    2010 TE250
    Sharing some info I’ve learned today...
    I’m fixing my bent radiator and decided I should get some new coolant. And I noticed the stuff in the radiator now is blue. Hmm, that’s different from he green I’m used too!
    I did some searching and found this thread of particular interest that helped answer some of my questions:
    http://www.cafehusky.com/threads/what-type-of-coolant.10576/#post-104569
    Apparently my manual recommends Castrol Motorcycle Coolant, and I read the earlier bikes used to call for AGIP Cool Antifreeze. I found little info about these and was unable to tell what color they are, and they aren’t easy to find where I live. I suspect these are Ethylene Glycol based but I couldn’t find a spec for the AGIP stuff.
    And I saw some mention that the original blue fluid might be G11, apparently a European spec antifreeze, and that is apparently blue. It is also not easily available near me (even the local German car dealer has apparently moved to something pink in color, maybe G12).
    Now importantly, some of the sources I read said not to mix the blue G11 coolant with an Ethylene Glycol based coolant. Maybe bogus, but it sounds to me like the safest thing to do is to just flush the old blue stuff and put in something that I know what it is.
    I also found this interesting article by Dave Kimmey, the President of Engine Ice. Obviously a biased source, but much of the info still seemed good and informative. After reading it I decided to go with Engine Ice, especially as I ride in the desert. I don’t care so much about antifreeze, but I do want better cooling performance if it’s possible.
    Here is Dave Kimmey's article, for what it’s worth:
    Since it's starting to warm up and you folks will be getting your bikes out of moth balls, I thought I'd take a minute to give you some information and education about antifreeze/coolant products as well as some insight as to what coolants actually are and what their true purpose is.
    Now, being from Engine Ice, I am a bit biased and I admit it. However, most all of the products on the market are excellent products, but each has various uses and applications for them. We produce Engine Ice for specific high intensity and high heat applications. It really is not designed as an “everyday” coolant; it is for racing or high temperature applications. However, it can be used as an everyday coolant with no problem
    There are two basic types of coolant/antifreeze, Ethylene Glycol (EG) and Propylene Glycol (PG) and then there are surfactant products such as Water Wetter from Red Line for example. All of the products mentioned are good products, just offering different things.
    Ethylene Glycol (EG) – This is basically your “Prestone” type of products. Maxima’s Coolinol, Pro Honda Coolant and Spectro Coolant are examples of this type of product. It is basically the same as the coolant/antifreeze product you can buy at the auto parts store, but “silicate-free.” This is important, don’t get the stuff from the auto parts store unless it’s silicate free. Most are pre-diluted for easy use; they are diluted with a more pure distilled water or deionized water (deionized water is explained below). This is better water than what you can buy at the grocery store.
    You really shouldn’t call an EG-based product a “coolant,” an “anti-boil” product would be more accurate. EG is made very cheaply and its primary purpose is to eliminate boil-over and to keep your system from freezing up. That’s basically it. It is not designed to actually reduce temperatures. If you are driving a car or a cruiser-type bike that does not have a temperature issue, these are fine products.
    Water Wetter - It is an additive product. Water Wetter is what is called a “surfactant.” What this means is that it reduces the surface tension of the water or in other words, it allows the water/fluid to “rub” closer to the metal allowing it to better draw off heat. Water Wetter works and it is good stuff. However, if you add it to an EG antifreeze product your results are minimal. It will reduce temperatures, but by only a small amount. Added to water, you will see a significant difference in temperature reduction. But it will not raise the boil point of the water nor does it offer any antifreeze protection. So your engine may run a bit cooler, but when it gets hot it will “spit out” the coolant before other products do. That is not good, because now you’ll have less coolant in the engine. Using more than the recommended amount (4 capfuls to a quart) is a waste and it will not make any difference, only use their recommended amount.
    Water alone is not recommended. You do need to add some type of water additive to it. Water alone is corrosive and it does not keep your seals, gaskets, water pump and water pump impeller shaft lubricated enough. Make sure something is added to water, do not run it all by itself.
    I would not recommend Dex-Cool (the orange stuff). All reports and tests that I have heard of have not been good. It can "gel." It also has a tendency to clog up a motorcycle system. The radiator core and the system itself of a motorcycle is smaller when compared to an auto. I would avoid Dex-Cool and choose any other product before I'd recommend anyone using it.
    Propylene Glycol (PG) – This is what Engine Ice Hi-Performance Coolant and Evans Coolant is made of. Evans is 100% PG and has an extremely high boil point of well over 350oF. They recommend you make some mechanical changes to your system, such as a zero psi cap or a different radiator in order to use it. Their goal is to eliminate boil-over, not to reduce temperatures. At their recommended 100% PG use, you’d have a boil point in excess of 350oF. At 100% PG, it would not be as effective at dissipating heat from your engine as well as it has a higher viscosity. Water is the ultimate coolant. All coolant products are measured against water for its heat dissipation capabilities. The lack of water in the use of Evans greatly reduces its ability to cool your engine. If you’re running heavy equipment or an 18-wheel truck, Evans is probably a good product.
    Engine Ice is a diluted ratio of PG and Deionized water. The process of de-ionizing water eliminates all of the impurities that can do harm to your cooling system. Regardless if you are using tap, bottled, distilled, spring or R/O (reverse osmosis) waters, it can still contain minute particles of iron, magnesium, rust, lime and calcium. Many of these waters also contain chemicals, such as chlorine, fluorides and acids. Want proof? Take two different brands of distilled waters and perform your own taste test. They each taste different don’t they? If water were water, why would they be different? It’s because of the varying amounts of chemicals and minerals in these waters. These minerals and chemicals are what is the cause of scarring, scaling and mineral build-ups in your cooling system. Many also attribute these minerals and chemicals to water pump seal and gasket failures.
    Engine Ice was developed and tested in the heat and humidity of Southern Florida. Tests have proven to reduce operating race temperatures by as much as 50oF in some situations. PG is a lubricant and is a surfactant in itself, meaning it has more capability to draw away more heat than EG-based products and even Water Wetter. It is biodegradable and non-toxic. It will not kill your dog, nor will it kill the plant life at your favorite track or trail. It is also legal in AMA, CCS and FUSA road racing.
    Engine Ice has won over 275 National Championship Titles over the last two and a half years including the 2001 AMA 125cc West Supercross Championship with Ernesto Fonseca on the Yamaha of Troy YZ250F and in 2002 Chad Reed in the 125cc West Supercross Championship. You can bet that Yamaha Motor Corporation did extensive testing on Engine Ice prior to putting in into their premier bike in its debut year. It is also used an endorsed by the American Suzuki Amateur Motocross Program. Engine Ice sponsored racer, Darren Luck, won nine (9) CCS class championships in 2002 as well as earned the CCS Florida Expert #1 plate by the largest margin ever. Racers using Engine Ice won seven CCS Race of Champions National Championships at Daytona in 2001 and won an additional eight (8) in 2002.
    As for flushing the system, we recommend a very simple and cheap radiator flush.
    Go to your local grocery store and buy "White Distilled Vinegar" and mix that 50/50 with some distilled water.
    Fill the system with the 50/50 mix, run the bike until warm, let cool, drain and then run clear water through to wash out the vinegar. It's the same idea as cleaning your coffee maker. The vinegar is acidic enough to remove any scale or impurities, but not so harsh that it will harm your delicate seals and gaskets.
    WE DO NOT RECOMMEND AUTOMOTIVE RADIATOR FLUSHES...they're too harsh.
  2. JPinNC Husqvarna
    North Carolina
    2009 TXC250
    2009 KTM 300 XC-W
    Nice! Thanks for passing it on -- good read. :thumbsup:
  3. waserman Husqvarna
    Delaware,USA
    09 TE510
    BMW KTM Honda
    I've been using Engine Ice for a couple of years in my bikes with good results . I tried it 1st in my TE after the initial break in of the motor and then also added it to my "Stupid Motard" as my wife calls it . I've never had any heat related issues in any of the conditions I've riden in, with either bike. :thumbsup: IMHO it's good stuff
  4. nickterc Husqvarna
    TE 610ie
    I use Engine Ice tooo with very good results so far,and please mind that i live in Greece with summer temps way over 40 degrees Celcius!
  5. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    2013 Kawasaki ZX-14R
    I do like Engine Ice and use it. My experience with it (on sportbikes with temperature gauges) isn't as dramatic as Engine Ice claims, but it did make a difference. My operating temperatures didn't change much, but I did notice that when I'd be in a situation where the temps would climb (stuck in rush-hour traffic, for example), my temps would drop down much more quickly once I got moving again.
    Another product I have used with similar results is PG 7th Gear coolant.
  6. typeone Husqvarna
    central MA
    07 TC270 + 09 WR165
    08 X4 146 + 13 250RR
    i run Engine Ice in both my Huskys, never had an issue. love that you can flush it in the yard. (same goes for NoToil airfilter products, rinse right in the sink!)
  7. krieg Husqvarna
    Matthews, NC
    Many in the past
    '12 Triumph Scrambler
    Engine Ice with a few caps of Water Wetter.
  8. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    I didn't know that! Engine Ice won't hurt the grass?
  9. typeone Husqvarna
    central MA
    07 TC270 + 09 WR165
    quoted from above...
    jtemple likes this.
  10. Tessier Husqvarna
    New Hampshire
    2011 TE310
    KTM 990 Adventure
