Stirlo
This bike has been giving trouble since day one...
First problem : decompression cam. Wrong one fitted, fixed under warranty, All good
Next... and on going.
Fuel pump stops intermittently. Some times it runs fine other times it sounds like it is trying to pump sump oil and then it comes good and run fine. I've had sensors changed, loom replaced (a problem known by Husqvarna with this model) and weeks spent in the dealer trying to sort it but it still rears is head from time to time...
The last time I tried to go for a ride I started the bike with the choke on and let it run for about a minute. I pushed the choke off, gave it a little throttle and it back fired and stopped. i tried to restart it but it only cranks and will not fire. I removed the plug and checked the spark, all good. Put a new plug in any way, also with plenty of spark, and still nothing..
Its been in at the dealer for a week and still no real cause found and they tell me it now starts and runs. All this with less than 1400k's on the clock
