Open in injector circuit fail
Discussion in 'EFI/carb' started by motorider115, Sep 21, 2013.
  1. motorider115 Husqvarna
    02 Yz 125, Klx 110,07 R6
    I have a 310 that has an intermitten problem that's throwing the fail light. hooked it up to ibeat says open in injector circuit as the current fails. my question is, when that fail occurs does it shut off the fuel pump, I noticed that when the fail is on the dash, the fuel pump isn't pumping when I cycle the run/stop switch.
  2. OlderHuskyRider Husqvarna
    Austin, TX
    Kwaka KLE, HD FXDWG
    Check your wiring diagram, on my bike, the Green with red stripe wire powers the fuel pump, the fuel injector and the coil.
  3. HUSKYnXJnWI Husqvarna
    Central Wisconsin, USA
    09TE450
    I worked on a 10TE450 that did that random injector circuit fail- yea the pump would not pump (very brief and intermittent), I cleaned up the connectors to the pump and injector and all was well- someone had filled the plugs with dielectric grease.
