250-500cc Overheating
Discussion in '2 Stroke' started by bsh7680, Jun 1, 2010.
  1. bsh7680 Husqvarna
    Cookeville TN
    12 CR 150
    04 PW 50, 08 KTM 50 JR Pro
    I have an 09 WR300 that wants to overheat when I am going up a long-gnarly hill. I came off of a KTM 250 and never had this problem. It does not do it any other time, anybody else had the same problem and might know what is thw cause.
  2. BikeSDP Husqvarna
    Longmont, Colorado
    None @ moment
    990 Adv, Multistrada 1200, 500 EXC
    Mine did that last season. Are you jetted too lean maybe?
  3. JPinNC Husqvarna
    North Carolina
    2009 TXC250
    2009 KTM 300 XC-W
    The KTM 300's are well known for this as well. Many feel that the issue can be sorted out or improved with proper jetting. On the KTM 300 the greatest benefit seems to come from going up one size (richer) on the pilot.
  4. PC. Husqvarna
    Beaverton, OR
    CR165 & CR144
    KTM500
    My 300 boiled over one time not too long after I got it. I've since drained the OEM coolant and replaced it with some over the counter junk and it hasn't hinted at overheating again. And I've had it in some precarious situations that it probably should have overheated.
    IMO the Agip coolant is junk.
  5. krieg Husqvarna
    Matthews, NC
    Many in the past
    '12 Triumph Scrambler
    Try Engine Ice with 3 capfuls of Water Wetter. :thumbsup:
  6. motosapiens Husqvarna
    kuna, idaho
    what jetting are you running? even with stock carb and fairly lean jetting (30p/clip 2/ 440 main) i couldn't get mine to overheat even on long 1st gear clutching climbs in deep soft sandy stuff. it was definitely starting to get warm then tho.
