Paint chips (?) in oil filter after 270hrs
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by ray_ray, Sep 11, 2010.
  1. ray_ray Mini-Sponsor
    The Philippines
    I just changed the oil in my 08 TXC250 again and it has ~270 hrs on the bike ...The odd thing is the SS filter and the larger screen at the bottom of the engine both had what appeared to be many red paint chips in them ... After all these hours is it possible paint is still flaking off something internally or is this something else?
  2. ghte Husqvarna
    Bright, Victoria Australia
    I have had a little bit of red on my screen in the past and did not worry about it Ray. No issues developed (is you oil filter paper red perchance)
  3. ray_ray Mini-Sponsor
    The Philippines
    I use an SS filter and it had many of the red specs in it also ... I usually have a few of these specs but this time the red was very abundant in the filters ...
    The bike is running well and the drain plug had just the few shavings...
  4. Coffee CH Owner
    You bike ate a Honda :p
  5. ray_ray Mini-Sponsor
    The Philippines
    I was riding with a couple red ones the other day ... maybe my Husky was hungry ;)
  6. Last Lap Husqvarna
    West Creek, NJ
    It's the loctite that they use on the case halfs. It's not thread locker it's a gasket maker type. I think it's loctite 230.
  7. ray_ray Mini-Sponsor
    The Philippines
    Interesting & that triggers a new thought ;) ... I did use some red silicon sealant on the valve cover and on the breather hose fitting coming out of the valve cover cap to stop some small leaks ... I bet it is this stuff and is the reason why so much showed extra up in the filter since my last oil change ...
  8. Rusty Nuts Husqvarna
    Lidsdale Australia
    2010 TE310
    have just done the filters on my 2010 310 at 130km same red gasket material .wont get worried unless i find shiny metal stuff
  9. krieg Husqvarna
    Matthews, NC
    Many in the past
    '12 Triumph Scrambler
    I like this theory! :cheers:
  10. kouack Husqvarna
    Montreal
    smell like fish taste like chicken:lol:
  11. ioneater Husqvarna
    NW Texas
    2010 TXC 250
    08 Sprint
    Generally a great troubleshooting technique: What maintenance was recently done to the machine? What has changed since the last use? Where were things disturbed?
    I have to use that stream of thought nearly every day on flying machines with issues. Most times it greatly reduces the amount of time required to isolate the problem. Then again, sometimes stuff just happens!
  12. ray_ray Mini-Sponsor
    The Philippines
    Right and good troubling-shooting technique ... I had forgotten I put some silicon sealant around the value cover the last time I checked the valves... I'm thinking now that this is why the abundance of red specs came from ...
  13. ioneater Husqvarna
    NW Texas
    2010 TXC 250
    08 Sprint
    Am glad that's all it appears to be good for you, Ray. Good to see the high hours on that little beast! I hope my 08 holds up as well!
  14. ray_ray Mini-Sponsor
    The Philippines
    Lots of riding is on the street at < 6500 RPM and on the trails I try not to REV past 10G too often ... But the vapor always stores some 12G number as top RPM hit :) ...
    After the engine got loose, it just runs up to top of the scale very quickly...
  15. ioneater Husqvarna
    NW Texas
    2010 TXC 250
    08 Sprint
    Yeesh, editing my previous post. Am glad it is GOOD for you, LOL
  16. Seahorse Husqvarna
    Could be some particles from your clutch .......:thumbsup:
  17. A.Breton Husqvarna
    GA
    :thumbsup:
    Most likely some anaerobic sealant
