All 2st Part Cross-Reference Listings
Discussion in '2 Stroke' started by MattR, Sep 12, 2012.
  1. MattR 2T Forum Clerk
    Temperance, MI
    WB165, SM610
    Yamaha FZ1
    I am posting this thread on behalf of Damian (CH Member: AUSKY)
    Cafe Husky Members,
    Over the last few years, I have been involved in restoring a few different Huskys & have been chasing up parts for my 1995 WR 125 & 2000 WR 360 that will fit onto these bikes.
    I have made up an extensive Excel spreadsheet with 18 years of various different part numbers & info for the 125/250/300/360 & I would like to share it with everyone & make it a sticky.
    It has been made up from Hall’s & Husqvarna Outlet parts catalogues that I have downloaded from the net, so im not exactly 10 % on the part numbers just what has been indicated in these catalogues.
    From,
    Damian (aka: AUSKY)
    There are 2 files attached (Excel format):
    • 125 parts (from 1994 - 2012)
    • 250/300/360 parts (from 1992 - 2012)
    Sonnie Mee, apariah, totemax and 3 others like this.
  2. AUSKY Husqvarna
    Cairns, FNQ,Australia
    08 TE510 96 WR125 00 WR360 13 WR165
    1999 XR250 83 YZ 490
    Thanks Matt,
    Damo.
    rockdancer and Blakelpd5 like this.
  3. Dirtrider1 Husqvarna
    Germany
    WR125, WR250, TC450, TE250, TE610
    Many thanks!
  4. jason380 Husqvarna
    WV
    1999 WR 125
    99 KTM 380, 03 RM 250, 06 KTM 450
    This is great! Thanks for sharing!
  5. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    Well done Damo you are a legend - this is just what i needed Thanks mate Ashley ( Lapper)
  6. Bud70 Husqvarna
    QLD
    wr360 95,cr 125 98,cr50 00,te250meo
    4 wheeler110,crf150r 12
    good work Damo unreal thanks Bud
  7. mikey Husqvarna
    husqvarna wr 125
    honda cg 125
    Hi I have recently bought a husqvarna wr125 1996 2 stroke and I am having real trouble trying to find a barrel fo it mine has got a crack in sum 1 plz help me ??
  8. rxcrider Husqvarna
    None
    None
    When we find parts from a certain year that fit other years / models, even if the part numbers don't match, would this be a good place to post that info? For example, I just ordered a set of 1996 360 WXE radiator shrouds from ebay, because I'm fairly sure they will fit my 1999 WR 250, although they will look a bit different. If my assumptions turn out to be correct, it might help someone else some day since the 1999 LH shroud is NLA. I'll edit this post once I know for sure or will delete it if I am told this thread isn't the place for it. Thanks - Jonathan
    Edit: The left side bolts right up. The right side doesn't match up with the radiator mounting point. It could probably work with a custom bracket for the shroud on the right.
    dubbya-r and 2premo like this.
  9. gary alger Husqvarna
    wr125
    yz250
    Just letting everyone know a yz250 moose carbon fiber pipe guard fits a pro circuit wr300 pipe almost perfectly.
  10. Fastestone Husqvarna
    2002 CR 360, 1998 WR 360
    1999 YZ400F, 2001 YZ426F
    Have a 1998 WR 360, I'm looking for a clutch cable, it has a pretty good bend right out of the case for clearance from the water line from the case to the cylinder. The parts list has no cross reference for this. Any one know what else fits or where to get a new one ?
    Thanks...
  11. dubbya-r Husqvarna
    Roseburg, Oregon.
    1999 wr250
    1994 xr650l
    I'm in the very same boat. This info is GOLD for me. Thank you.
  12. kev900sp Husqvarna
    Scottsdale,AZ
    07 TC450 78 CR390 02 cr250 87 cr430
    Ducati 900SP, Cannondale , Maico 490
    I am changing over the plastic on my 2002 CR250 for the more modern stuff that came on the 2005-2007. I think the tank I need is a 2005-07 WR250 (2 stroke) piece. I can get a new one for about $300. Does anyone know for sure if this is correct, or have a decent used one they'd be willing to sell? Thanks, Kevin
  13. husk99 Husqvarna
    1994 Huskvarna WXE/WXC250 or CR/WR
    Hi,
    I have found that in some countries the same Husky was called a different name.
    So 92-96 CR,WR,WRE,WXE,WMX,WXC Parts, will mostly fit eachother.
    From what I can tell so far the WR=WXC and WRE=WXE
    (so maybe the CR=WMX not to sure on that)
    and were the CR's 5 speed?
    with the others being 6 speed?
    Is that correct?
    As an example many here think its a 92-94 CR 250,
    yet the piston is listed as a Wiseco 699M06700 for a WXE, ($160AU)
    and is apparently interchangable with a Wossner for a 92-96 WR/CR 250. ($160AU)
    The rod apparently interchangable with a 2000-2002 KTM SX 250 rod (req. crank pin mod) ($130AU+)
    Theres some prices in Australian dollars too to give people an idea what they are in for
    Cheers
  14. husk99 Husqvarna
    Anyone know which Crank Bearings and seals will fit a Husky CR/WR/WXE/WXC 92-96?
    + Big and small end bearings?
    Mine has no play just want to do them all at once ,and/or get the rod kit, as am Changing Crank anyway.
    Cheers
  15. husk99 Husqvarna
    I found some answers
    KTM 250 SX 2000-2002 Rod fits with just a slightly longer crank pin,
    So the big and small end bearings should fit.
    The small end is available aftermarket from wiseco, and is also used on Yamaha and others.
    Crank bearings, I am not sure on.
    The CDI's are interchangable on many Husky's
    WR250's 95-2010 apparently,
    WXE/WXC 250 and 360 93-96
    WR 300 2009 - 2010,
    and even some KTM CDI's fit some models.
    Petar likes this.
  16. John Perins Husqvarna
    wxc 360 1996
    beta, ktm, kawi, yammy you name it
    Just as a FYI the mid 90's husqvarna 250/360 wheel will fit a 2000 cr/wr 125
    Durangedgoat likes this.
  17. 96husky250 Husqvarna
    1996 wxe250
    Why can I not see parts cross reference??
  18. MattR 2T Forum Clerk
    Temperance, MI
    WB165, SM610
    Yamaha FZ1
    Both files are Microsoft Excel format (spreadsheets). Just click on the files and they should open for you. They open on my iPad fine.
  19. oneal Husqvarna
    uk
    1999 wr 250 returned home.
    07 TE 450 2005 TE 450 1999 CR 125
    You can use 97-01 Honda cr 250 piston direct fit, Small end bearing 18 x 22 x 22,. a direct replacement con rod kit Yamaha yz 250 1999 on.
    riz likes this.
  20. HUsky riding 78 Husqvarna
    1999 husqvarna cr250
    hi I have a 1999 Husqvarna cr250 and I am in need of a new crankshaft and I cant seem to find one any where would anybody know where I can find one or one that will work?
