125-200cc Part of powervalve broke down...
Discussion in '2 Stroke' started by Mr_X, Sep 28, 2010.
  1. Mr_X Husqvarna
    Singapore
    Hi,
    This pic is taken from my SM125 2008. Apparently the yellow marked thing above the carb broke down, which result in super boggy-ness almost immediately after the valve open. Now my bike cant go on high RPM. Anyone know this electronic thingy can be repaired? or should i order a new one?
  2. Motosportz CH Sponsor
    My guess would be ether a throttle position sensor or a device that makes it lean out on top like the YZ carbs have. If it shares a shaft with the slide actuator and moves when you rotate the throttle it is a throttle position sensor. This would explain why you have a bog when it is not working.
    Edit...
    Looks like a Deloto VHST carb with throttle position sensor...
    http://www.dellorto.co.uk/merchandise/products.asp?CategoryID=2&PartsectionID=44
  3. razornpc Husqvarna
    iowa
    off topic:
    what kind of carb is that?!?!?!?!?!?!?!!?
  4. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    Looks like a Dellorto.:thumbsup:
  5. Mr_X Husqvarna
    Singapore
    Thanks guys, yup its a 28mm dellorto carb. I fixed this problem by changibg to a keihin pwk 35mm. But another problem occurred... My piston seized, due to lack of 2t oil.
  6. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    http://www.dellorto.it/prodotti.asp
    a VHST 28 with optional TPS Perche??????
    these are definitly not Husky problems...you may want to stick with OEM stuff or the carb set ups that are tested among riders on this site. 32:1 is a very safe bet. Hope you get her fixed up.
    That thing on your carb is a TPS (throttle position sensor) it talks electrically to the ignition module. The powervalve is the mechical device that changes the exhaust port opening in relation to rpm.
    Hope you get her fixed up, Huskys need to be everywhere!!
  7. Mr_X Husqvarna
    Singapore
    The stock sm125 comes with the dellorto carb as OEM. Anyway, does a scratched piston and piston ring affect power loss?
  8. daxx Husqvarna
    france
    salut oui nouveau tps,qu'il va falloir le changer et regler avec la procedure!
    ton serrage doit venir de la
  9. Coffee CH Owner
    welcome. This is what google translate thinks you said:
    hello again yes tps, he'll have to change and adjust with the proceedings!
    tightening tone must come from the
  10. ray_ray Mini-Sponsor
    The Philippines
    Did you mix the oil \ gas ratio incorrectly?
  11. Vinduro Husqvarna
    Mississippi
    Yes, Scratched piston will indeed hurt power. You need a rebuild before you ruin cylinder if you haven't already.
