Parts Bag w/2013 TE 310 R
Discussion in '4 Stroke' started by Johnrg, Nov 20, 2012.
  1. Johnrg Husqvarna
    Santa Barbara
    2013 TE 310 R
    The photo below shows some parts that came with my bike. 2 keys for steering lock, USB with manuals, lever covers and some items I am not sure of. Curious what the angle brackets are for, the machined cone shaped fitting, and the small white plastic rectangular plug (w/chain). Appreciate any info.
  2. XLEnduroMan Heroes Ride Huskys. The others follow.
    Durham, CA.
    '18 Husqvarna 701 Enduro.
    '20 Ducati Hypermotard 950.
    Tun signal brackets, thing with chain attaches to usb stick for sticking the cap on when in use.
  3. Johnrg Husqvarna
    Santa Barbara
    2013 TE 310 R
    Cool... Thanks!
  4. Mike-AK Husqvarna
    Alaska
    2012 TE 310
    The turn signal brackets are useful if you decide to remove that ugly black plastic contraption off the back of your bike. I have since covered up the shiny metal with 2" shrink tubing.
    Johnrg likes this.
  5. Mike-AK Husqvarna
    Alaska
    2012 TE 310
    Here is what it looks like with the shrink tubing covering the brackets.
    TE in RC likes this.
  6. Johnrg Husqvarna
    Santa Barbara
    2013 TE 310 R
    Cleans the tail it up well. I may do the same... I might try some some Plasti-Dip coating on the brackets.
  7. Mike-AK Husqvarna
    Alaska
    2012 TE 310
    Thanks. I think so also. I did not consider Plasti-Dip. That's a good idea. Post pics when you are done. If you are interested, I got the rubber license plate mount from BMP. It mounts using the taillight bolts, but I also zip-tied it to the fender stub under the plate to keep it from flapping around.
    Johnrg likes this.
  8. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    The aluminum cone washer is for the hand guards where the lever bolt passes through. Looks like the other black bolts are for use of aftermarket hand guards if I remember.
    My 449 came with a few extra nuts and bolts, which turned out to be very handy once I found out the hard way that a six year old seemed to be the one to do the final bolt check before I got my hands on it.
    Indorider likes this.
  9. Johnrg Husqvarna
    Santa Barbara
    2013 TE 310 R
    The lever guards were installed. Not sure if they were done on uncrating but will check if the cone washer was left off... Assumed those black bolts/nylocks were for the levers without the guards.
