Where in the US do you go to get parts for a Magura Hydraulic Clutch? Be nice if the have a fiche or parts diagram to look at? Thanx!
What ive found (for a clutch m/c) was to go to a KTM dealer, as some years of KTM used the same components. If you find a smart parts guy, that will make the search easier.
you can call magura, they have rebuild parts for it, not cheap, My kx500 came with a magura hyd. clutch, weep ed at the master cyl. The price for the rebuild kit, and the fact I didnt like the clutch anyway, made me choose to go manual. Mike
http://www.factoryproracing.com/ they are a Magura dealer just need to tell him what size master cyl you have (think our Husky one is a 9.5mm), I replaced one but dont remeber the size. Also if you look in the Husky parts book for your model they list all the rebuild components and some parts are broken out for purchase. The rebuild kit comes with all seals and a new piston and is not expensive, call a dealer.
This is one of the add on ones that someone put on a WR125. Factorypro doen't have the stuff for the bottom. Very helpfull guys!
Thanx for the help. I called Magura direct since this is one of those add on clutches. The rubber part on the slave rod is not available. They are trying to get one off a new one to send to me. I also needed the lever boot at the master cylinder.
are you talking about the rubber cone shaped thing that goes into the master cylinder where the rod goes thru? If Magura can't help, I think I have an extra that should work. PM if ya want. A KTM rebuild kit should have that though...I think the kit is around 25 bux.
It is on the bottom slave cylinder. Rubber peice about an inch long that scrapes the mud off the rod that goes to the clutch lever on engine.
Parts Unlimited sells Magura, so any motorcycle dealer in the US can get the parts for them. http://www.parts-unlimited.com/part...mentIds=13,15,20,15,16,4,14&searchTerm=magura Also, the cable to hydro conversion slave is absolute junk and should be switched back to a cable only setup. 2 people I personally know and ride with have had the slave give them nothing but problems and eventually fail.
Hall's Cycles? That's where I got mine. They were warranty parts, though. You can get a PDF manual that includes all part numbers here: http://www.powersports.magura.com/en/products/clutches/prod/hymec-off-road-1/info/downloads.html
About the same for the rebuild kit, but thats only a couple rubber cup seals and a spring I think. 32 bucks for a clutch lever wow. I really didnt like mine, the pull on it seemed the same as with a cable. I bought some mineral oil ( thats what it uses for fluid) from a bicycle shop to top mine off and it was like 20 bucks for a little bottle. You know mine is just sitting around, anyone wants it, shipping and 10 bucks it's yours, just pm me. I really dont think its worth it, but some people swear by them. It does weep a little but worked when I took it off the kx500, I dont know if it fits others though. Mike
you guys I hate that lever boot I have installed 3 they always disappear!! I think they blow off on the trailer on the road??? I even worked a zip ty on the last one, and noticed it gone just yesterday!! And yea I will get another (safety wire this time!!). PS my master is leaking past the seal again!!! My love/ hate relationship with Magura continues!!
