hello all, I have 08 te450 with arrow pipe, power up, etc. just installed pcv and autotune. Im a bit confused with configurations. the only map i could find to start with was 09 te450 with just power up kit. I have a sputter in 1st and 2nd at 6100 rpms. everything else feels good i think. does the autotune just correct as it goes? my afr fluctuates at 13 to 13.5. should i see numbers changing on the base map? im totally confused. also, i noticed and import pwc3 map button in the software and tried loading the 08 map with all the configurations i have. but it didnt take it properly and got an errro. i could use some basic suggestions if anyone has time to explain. thanks chris
Here's the biggest thread on PCV and autotune. http://www.cafehusky.com/forums/showthread.php?t=4815&highlight=PCV Maybe easier to get someone's attention there.
