PCV for 2008?
Discussion in 'EFI/carb' started by MorrisBetter, Jun 13, 2011.
  1. MorrisBetter Husqvarna
    Nor Cal
    TE501s
    BMW R1200GS
    I'm getting mixed messages WRT the Power Commander V for 2008 bikes. Will the PCV work for 2008, or do I need to use the PCIII? Does anybody have first-hand information? Part numbers? Recommendations?
    I'd like to go with just the PCV, but keep the option to add the auto-tune later if the off-the-shelf maps and/or manual tweeking don't do it for me.
  2. Tee-Dub Husqvarna
    PCV should be just fine
  3. seymore Husqvarna
    Boise, ID
    I have the PCV with Auto-tune installed on my 08TE450. It made a significant difference. I was able to find a lot more mid and top power as well as improve my MPG.
    Dynojet doesn't have a part number for the 2008 since the PCV came out in 09. All the Husky's except for the 449 & 511 use the same PCV, but with different maps preloaded.
    You can install a PCIII map in the PCV for your 08 or start with a zeroed map and let auto determine the values.
    I stock the PCV & AT for the Husky's. Send me an email and I'll get you a qoute.
    info@semcodesigns.com
