I'm running a Power Commander V & Autotune using the stock map. PC don't give any target AFR values though. On most of the threads it looks like 13.2 across the rev range and above 5% throttle seems to be the standard. I read on one of the threads that the fuel pump is close to maximum duty towards full throttle and therefore wonder if the air fuel ratio should be a bit leaner, say 14.0? Can anyone share any improved target AFR values for a stock husky?
